Old October 29, 2015, 05:55 PM
Default Question on Hard drive benchmarks
Hello
I have run two Mushkin SSDs in raid 0 for several years now, I just had one disk die and replaced it today. I re organized my case and wiring and installed a clean copy of window 7 ult.
I wanted to make sure everything was running as it should and did a Crystal disk mark test as was very surprised by the numbers, I then tried AS SSD and they were identical, I then decided to try ATTO before ripping things apart and got the numbers I expected (slightly lower then before but ok)
Can someone explain why I got different numbers in each and what that means. Is it functioning as it should (2 raid 0 ssd's using intel mb internal raid)
Thansk
edit forgot the pic
Old October 29, 2015, 06:54 PM
MARSTG's Avatar
Atto shows 1GB/s reads, which is normal, what is the issue?
Old October 29, 2015, 08:37 PM
why the others are so different
Hard Drive Question CyHawk Storage 8 August 17, 2010 09:00 PM
Hard Drive Formatting Question shayan288 Storage 10 August 10, 2009 05:43 PM
Hard Drive benchmarks Mr. Gruntsworthy Overclocking, Tweaking and Benchmarking 2 March 13, 2009 09:34 PM
Failing and new hard drive question matsta31 Storage 10 January 19, 2009 06:54 PM
format hard drive question Jamz O/S's, Drivers & General Software 6 March 26, 2008 11:29 AM
