Old June 25, 2015, 07:39 PM
Default Overclock 5820K
Hi,
Recently purchased a 5820K and copied a video tutorial on Youtube for overclocking but I have a few questions.
Below are the settings I have done to obtain my 4.5 GHz on my 5820K with my MSI X99 SLI Plus
Cooler: Corsair H100i GTX
CPU Ratio: 45 (Original 33)
Base Clock: 100 (Original 100)
VCCIN Voltage: 2.1 (Original 2.0)
CPU Core Voltage: 1.3 (Original AUTO)
1) What is the difference between VCCIN and CPU Core Voltage?
2) Under AIDA64 Stress test my TEMP is stable at 80C, but I would like the temp to be around 70 - 75 MAX, do I start decreasing the CPU Core Voltage or VCCIN to see if I can maintain my 4.5 GHz with lower voltage?
Thanks,
Excal
Old June 26, 2015, 01:18 PM
Johan45's Avatar
You probably didn't need to increase the VCCIN at all and if you haven't tested with anything but 1.3v on the core then yes lower it and test. Rinse and repeat. There's so much variation in the CPUs that someone elses setting aren't likely going to be ideal for your setup.
Not sure if that's my wife's cooking or if I'm overclocking too much.
My First Overclock Cardboard box with DSL Overclocking, Tweaking and Benchmarking 11 April 11, 2012 05:11 PM
I want to overclock but need help Blu Overclocking, Tweaking and Benchmarking 11 April 11, 2012 02:47 PM
I3 540 wow overclock on air gingerbee Overclocking, Tweaking and Benchmarking 6 June 3, 2011 12:12 PM
Overclock on RAM quikgp RAM 6 December 12, 2009 12:59 PM
How does this ram overclock? klaiboi RAM 7 March 23, 2008 05:42 PM
