Old May 11, 2008, 08:37 PM
Originally Posted by BALISTX View Post
I don't agree as I have seen others push the 2140 to 2.8-3.0 with an AC7 Pro and have lower load temps than 57C. However the fact that I have added 2 extra fans for a total of 5 120mm fans (3 intake, 2 exhaust) and the temps haven't changed would also lead me to believe that a) the limitations of the AC7 Pro. b) I need to reseat the AC7 Pro.
The AC is a great supplemental cooler to replace the stock fan but I don't recommend it to anyone doing any serious overclocking.
Old May 12, 2008, 03:57 AM
3.0charlie's Avatar
If you do reseat, check the flatness of your AC Pro.
Old May 13, 2008, 06:10 PM
BALISTX's Avatar
So I decided to push a little further. I upped it from 2.6GHz to 2.8GHz and ran Orthos and after 30 mins my temps were showing 62C in Core Temp. The Easy Tune 5 Pro was showing the CPU temp at 46C. I don't know which one to believe. Here the settings I did.
FSB: 350
CPU Multi: 8x
vCore: 1.35
Memory Speed: 1050
vDimm: 2.1
On a plus side I broke 10,000 in 3DMark06
For the meantime I backed it down to 2.0GHz until I get some MX-2 thermal paste ordered. How Ever I noticed that Core Temp is still showing my temps at 36C at idle which is pretty high. I have tried 3 different versions of Core Temp and I have tried Speed fan, it says the same. TAT shows it running at 40C
This comfirms that I will need to reseat the AC7 and I think I will lap it as well.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old May 13, 2008, 06:15 PM
3.0charlie's Avatar
There's a nice WC setup right next to me as I type this, waiting just for you...
Old May 13, 2008, 06:19 PM
BALISTX's Avatar
I so want that WC setup but unfortunately bills have to come first grrrr.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old May 13, 2008, 07:31 PM
sswilson's Avatar
FSB: 350
CPU Multi: 8x
vCore: 1.35
Memory Speed: 1050
vDimm: 2.1
Core temp and CPU temp are two different readings. AFAIK nobody trusts the CPU temp because nobody is really sure what it's reading.
Old May 13, 2008, 07:38 PM
BALISTX's Avatar
ah so Core Temp it is. I hoped it I wouldn't have to reseat it. What a PITA this is going to be.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old May 13, 2008, 09:33 PM
I think you should reseat it...and check the contact between the CPU and the HSF. I found out my ACF7 is better than my Ninja..albeit being quite a bit louder Maybe because the Ninja is too big for the push-pin design...or maybe I just didn't mount it right or applied too much/too little paste all the times I mounted the Ninja.
The idle temps are a few degrees higher, but the load temps are lower. With my Ninja and S-Flex F temps were 73 max, now they're like 66...but it's a lot louder.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
  #19 (permalink)
Old July 14, 2008, 12:51 PM
UrbKlr's Avatar
Have you tried lowering your voltage? I have a computer with a e2140 sitting right beside me, it's in an Antec 900 case, and has a Freezer7. I run it at 2.8GHz on 1.25v. The Freezer's are great, but not awsome, 50's load should be well within expectations.
BTW, My Freezer lapped keeps my e6550 at 56c load, at 3.4GHz 1.42v.
AMD Phenom II X4 920 3.78GHz (On M2R32-MVP)
ASUS M3A32-MVP Deluxe Wifi/AP Here, but not posting.
4GB Crucial Ballistx Tracers and Corsair XMS2
VisionTek Radeon HD4850 VF900 735/1100 1.148v
  #20 (permalink)
Old July 14, 2008, 03:51 PM
BALISTX's Avatar
Well it turns out that the reason for the high temps was because the AC7 Pro and the CPU were not making proper contact, two of the push pins were damaged and not holding the AC7 on properly and I guess because of the weight it was slowly pulling the AC7 away from the CPU and that's why the temps were getting higher, even when I clocked the processor down to 2.0GHz, my temps were hitting 50C-53C at idle.
Right now the rig is out of commission till I decide on either getting another HSF or I may do watercooling. But I'll be getting a new processor, either a Q6600, an E7200, an E8400.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
