| | LinkBack | Thread Tools | Search this Thread | Display Modes |
| I have a 2X1 GB double sided Crucial Ballistix. I'm able to push it over 1200mhz and pass the memtest at 2.2 V. However, in windows, it fails the Prime95 torture test. Any ideas why this might be so? My rig is a Q9300 with P5K Deluxe. |
| If you plan on upping the vdimm then like Steve said you will need proper cooling. There is a couple of options you can do. There is the Antec SpotCool - $19.43 @ NCIX and the Corsair Dominator Airflow Memory Cooler - $27.44 @ NCIX |
| So, the highest voltage without cooling is 2.2V? I think I'll just try to loosen timings. There is this Transaction booster funcion in my bios. I can leave it auto, disable with options from 0 to 3 for compatibility, or enable. Anyone familiar with this? |
| I have played with three sets of ballistix in the last year and have had little luck getting them to run over stock speeds.
__________________ System1: evga 680i rev. A1 // Q6600 @ 3.51 // evga 8800 GTS 640MB // 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // Swiftech Stealth// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump System2: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 7900GS // OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
| When you say "passed memtest", how many runs did it pass? Leave it running overnight for preference, get yourself a dozen passes to be certain. That aside, I don't believe memtest fully stresses the memory controller, as opposed to a program like Prime. Are you certain that your FSB is stable? Are you certain that your CPU speed is stable? Either of those can cause Prime to fail, but you'll have to use a process of elimination in order to determine which one. To the best of my knowledge, Asus' transaction booster is a fancy name for adjusting the memory controller's tRD timings. If you're determined to run beyond the memory's rated speed, you should probably just disable the transaction booster, and pull it down a level or two. It'll cost you memory bandwidth, but it might just make the difference. Later on, once you've got a stable OC, you can try notching it up slightly to regain as much bandwidth as you can. Personally, I suspect that any memory speed gains you see by using the relaxed transaction booster settings will be negated by the looser MCH timings. And since you're running a quad-core, you'll run out of FSB headroom before you run out of memory speed. And DDR2-1200? That's fast. If you don't plan on aiming a fan at those modules, you should probably slow things down a little.
__________________ QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB |
| Display Modes | |
