Old January 6, 2015, 06:08 AM
gee gee is offline
Default help overlooking evga gtx 750 (not Ti version)
Should some on tell me how to overlook the gpu peppery I have done it abit but only got about 200 points and an 10 frame rate increase but it crashes or stops working (not broken) I've tried increasing the clock voltage but no difference and temperature doesn't go any higher than 51 degrees c.
Posted twice on my phone don't know how to delete one sorry
Old January 6, 2015, 07:36 AM
MARSTG's Avatar
Installing EVGA's Precision X should help you. The GTX 750 is not clocked too high, the EVGA single fan models are around 1028 MHz from what I have seen. And they don't clock too much either, I have a GTX 750 Ti clocked at 1176 MHz and works fine at 1300 MHz but any higher it would crash in a few hours. However everything I play works fine at 1080 with all the eye candy. If you need more power than that you might want to change it to something different. I was using it mainly for folding.
Old January 6, 2015, 07:59 AM
gee gee is offline
Okay thanks I'll give that a try
[WTB] 2x GTX 480 AR version Zygote Buy/Sell & Trade 0 July 11, 2012 08:56 PM
Evga GTX 580 3GB version.... rjbarker Video Cards 16 May 1, 2011 08:04 PM
[FS] Evga GTX 280 SC "TR" (Limited Warranty version) rjbarker Buy/Sell & Trade 43 February 25, 2010 04:35 PM
Evga X58 - BIOS Version Shipped rjbarker CPU's and Motherboards 5 January 19, 2009 12:19 PM
