Old May 7, 2008, 10:46 PM
J2TheROC's Avatar
Default Need an OC buddy!
Is anybody out there willing to help a fellow canuck out, I know there are guides and i have read them.. but id rather have live help over msn or something...
Im trying to get to Oc'ing but so far ive just gotten as far as running the TAT which only shows 2 cpus for my q6600 running at about 30degrees at stock
1.) Is this a good starting temp to begin oc'ing? I want to reach about 2.8 to 3.0 ghz (currently using Zalman cooler 9700)
2.) I downloaded CPU-Z and it shows my system is at FSB:Dram is running in 2:3... i want to get it to 1:1 ... so how do i go about doing that?\
Thanks yall
Old May 8, 2008, 05:30 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Can you help us out with listing your full system specs?
Old May 8, 2008, 07:59 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeah we need to know what board you are using.
Old May 8, 2008, 08:58 AM
J2TheROC's Avatar
thx for the quick reply guys.
Im using an asus motherboard its a p5e x38
ASUSTeK Computer Inc.
current video card is a faulty
radeon 1900xt.. (holding out until the 4870 comes out)
processor is a q6600 @ 2.4ghz g0 stepping
cooler is a Zalman CNPS9700 using default thermal grease it came with
in my bios i have a tab called overclock tweaker or something
oh yeah ram is 2x2gb Mushkin ddr2 800mhz hp2 @ 5-4-4-12
Old May 8, 2008, 10:30 AM
I hit 3.5 ghz with a similar setup (asus p5ke wifi zalman 9700 q6600) so i'd say you've got a great chance of getting 3.0. I was getting 3.0 with only a fsb change. Just try stepping up your fsb (set fsb to manual and increase the number by 10 or so till you get to 3.0 or it wont boot anymore) and leave everything else on auto. that cooler wont max out untill (about) 3.6 in my experience, unless of course you have terrible airflow or nasty cable management in your case. ;) and use "coretemp" to monitor your core's temps.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old May 21, 2008, 07:19 PM
J2TheROC's Avatar
Hey man, I oc'd my cpu through the asus tool ai suite to 2.9ghz and im happy with that speed.
My temps are @ around 28-34 idle
so my question now is that my system is running at 2:3 so how do i get this to 1:1?
I was wondering in the bios DO i just set the dram frequency to match the fsb? which would be 1300 something? and all is fine?
I've attached my cpu screenies
Thanks
Old May 21, 2008, 07:38 PM
JD JD is offline
Thanks
You'd set your DRAM Frequency to the Bus Speed (330MHz) if you wanted to run 1:1. Though in your BIOS, it may be 660MHz (330x2).
Each BIOS is different, some use the non-multiplied number and others use the multiplied number. DDR = Double Data Rate, thus the multiplication by 2.
However, I'd set the Bus Speed to 333MHz (1333MHz FSB), and run the RAM at 400MHz (800MHz).
Old May 21, 2008, 09:56 PM
J2TheROC's Avatar
Hi thanks for replying so fast. Are my temps ok to oc anymore if they are in that range of 28-34 idle? If i do what u say and make RAM at 400 mhz and bus speed at 333 then.. it wouldnt be 1:1? so wouldnt it be worse?
Old May 22, 2008, 08:15 AM
Eldonko's Avatar
28-34 on a quad is fine, nothing to worry about, just keep load below 60 and you are good. At that speed, you can probably tighten trcd and trp to 4, with about 2.0v on mem.
Old May 22, 2008, 08:00 PM
JD JD is offline
You don't always have to run 1:1. Even still, you can run the FSB at 333MHz with the RAM at 333MHz (666MHz). 330MHz FSB is just odd to see, that's why I'm saying 333.
