Old November 9, 2014, 12:49 PM
qwerty's Avatar
Default Pentium G3258 Overclocking
Well, I am new to Intel overclocking as this is my first Intel machine since I had a Pentium 700Mhz. At some point I will upgrade to an i5 or i7 but for now I will be happy using this chip. My goal isn't to kill this chip but to have a stable overclock that's all. Not looking to break any world records or anything. Perhaps I have achieved that already, I don't know yet.
I have managed to overclock my chip to 3.9Mhz stable at 1.25v with 29c idle and 49c under load using an Arctic Pro Freezer 7 cooler. Seems like a moderate overclock to me. Ideally, I'd like to get up to around 4.2Mhz, that would be a sweet spot for me.
The rest of my setup is in my signature.
I cannot seem to get it to go any higher for some reason. I try to go to 4 Mhz and it freezes on the "Starting Windows" load screen, even if I up the volts up to 1.375. So maybe I am stuck at this speed? I will keep trying to get higher OC's.
If anyone has overclocked please share your results and setting as I would be interested in seeing what you managed to get.
I have read on numerous websites of people getting to 4.4 Mhz and higher but they were mostly on water setups, H80's and such.
Thanks for reading and happy overclocking!
Intel i5 4690k|DeepCool Captain 120 Cooler|Gigabyte Z97-Sli|Gigabyte GTX 770 4GB OC|2xSamsung Pro 500GB SSD|1TB HDD Raptor|EVGA 850W P2|ASUS VG248QE 144Hz|Logitech G700s|SkullCandy Slyr|Blue Snowball|Logitech c920
Sadly, I had no choice but to go Intel since AMD is not a viable option right now. I eagerly await the upcoming Zen and Polaris offerings.
Old November 9, 2014, 01:32 PM
Bond007's Avatar
Did you turn turbo boost off?
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old November 9, 2014, 01:33 PM
c3p0's Avatar
I have to say there is no need for watercooling to handle 4,4 Ghz on a pentium. It's a relative cool chip that doesn't get very hot like amd's fx or i5's. You only need a good cooler which you have.
Now for my setup. I left the voltage on auto which blasts 1,3 volts at it under full load. Only messed with the bclk frequenzy and the turbo multipler. So:
Multipler: 44
BCLK,PEG: 102 mhz
vCore: Auto Idle 1,07volts, Load 1,29volts.
Temps (22 C ambient): 30 idle, 50 load.
~GirlyIT droid #Su~ Pentium K G3258 4,4Ghz :)
Old November 9, 2014, 04:02 PM
3.0charlie's Avatar
Mine runs @ 4.5 with 1.275V Vcore. WC is not required, but I had a H80i on hand so why not. Runs cool at 49C under Linx load. I could have pushed it further, but saw no need to do so.
Hydro-Quebec is salivating...
Old November 9, 2014, 04:05 PM
qwerty's Avatar
I dont know what Im doing wrong then, maybe I just have a bad chip. The only things I've touched are the voltage and the cpu speed. Turbo is off. I will try to read and find out what other settings I need to change.
Old November 9, 2014, 04:11 PM
Bond007's Avatar
It has to be a setting. I don't think I have heard of anyone having issues getting above 4ghz.
Old November 9, 2014, 04:14 PM
qwerty's Avatar
Originally Posted by Bond007 View Post
It has to be a setting. I don't think I haven't heard of anyone having issues getting above 4ghz.
Yes, I agree, I have to look closer it doesn't make sense for it to all of a sudden freeze up on a 100 mhz increase.
Old November 9, 2014, 04:24 PM
That is really helpful. My sister should get that CPU for christmas. I couldn't find a like button.
Old November 9, 2014, 05:23 PM
Bond007's Avatar
Are you able to put screen shots up of your bios (uefi) settings?
Old November 9, 2014, 05:30 PM
sswilson's Avatar
How did you make out with the bios'? Did you try one of the newer post 2001 ones or did you (like me) chicken out and decide not to mess with something that's working? :)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Intel G3258 + board for overclocking Dzzope CPU's and Motherboards 11 April 17, 2015 11:03 AM
Intel Pentium Anniversary Edition G3258 MARSTG Reviews & Articles from the Web 1 September 7, 2014 12:31 PM
Overclocking Pentium 4 540 - no change?! trodas Overclocking, Tweaking and Benchmarking 11 October 6, 2013 09:46 AM
Dry Ice overclocking! Celeron and Pentium D! Wankerfx Overclocking, Tweaking and Benchmarking 34 February 5, 2008 01:22 PM
Overclocking Pentium D820 silverchair Overclocking, Tweaking and Benchmarking 2 September 12, 2007 07:57 PM
