Old September 6, 2014, 08:47 AM
Trial Member
Default Oveclocking Help 3770k
Hi I've overclocked my 3770k to 4.3ghz at about 1.28 voltage and the temperature stays at about 75-80 degrees.
But I still haven't gotten it stable, it runs nice and stable at max 80 degrees and then suddenly after 10 minutes the temperature rises to 90-100 degrees under the span of a few seconds and it BSOD me. Why is this happening?
I have a big ass Cooler master cooler, with I think 12 copper tubes in total, I dont know the name of it, but it was expensive. Should I be able to get better overclocking with that than I am getting now?
Old September 6, 2014, 08:57 AM
TTC TTC is offline
Sounds to me like youre running to hot sir. Get watercooled.
Old September 6, 2014, 11:10 AM
ZZLEE's Avatar
Try this OCCT 4.4.1 Available !
Lock your multiplyers and voltages in BIOS.
Run CPU test with the monitor window open. You will see a mem spike and Voltage spike soon as the program realy starts going. takes a minute or then it will ramp up. you shuold see your isues as soon as CPU hits 100% and Mem hits 90%.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old September 6, 2014, 11:17 AM
Water shouldn't be required to get over 4.3. What specific cooler are you running? If you are running that hot (assuming you do have a decent cooler), then I would suspect a bad mount or a bad TIM application. Try taking the cooler off, and check how the TIM is spread. Reapply new stuff and ensure you have it properly mounted.
Also, unless you have a very poor overclocking 3770k, you should be able to run 4.3ghz at a much lower voltage. I think I was able to get my 3570k at 4.2ghz around 1.13v. So I would suspect somewhere around 1.15-1.18 should have got me stable at 4.3. Have you tried lowering voltage?
EDIT: Also, do you have decent airflow in the case? What case, cpu cooler, and case fan setup do you have?
Desktop: Antec Three Hundred, Z77-D3H, 3570K undervolt @4.1ghz with Zalman Optima Cooler, Corsair Vengeance 2x4gb@1866mhz, MSI Cyclone GTX 460, Seasonic S12II 500W, WD Black 1TB, Intel 530 120GB
Old September 8, 2014, 10:09 AM
i know the 3770k runs a little warm but i was able to get 4.5 on mine on air with max temps in the 62-67 area. prolly need to either upgrade the cooler and paste or its really just a shitty ocer. 1.28 is higher voltage then mine though .
[WTB] WANT: i7 3770K cpu justmehereajax Buy/Sell & Trade 3 May 31, 2014 06:54 PM
Should I have gone with i7-3770K instead? sakage.shinga CPU's and Motherboards 11 January 12, 2014 12:30 PM
[FS] i7 3770k Rasparthe Buy/Sell & Trade 1 January 27, 2013 01:51 PM
I7 3770K Your_friendly_gamer Price Check 2 October 6, 2012 11:37 PM
