| Quote:
I have not even touched those LOL. Not even really sure where to access them lol. For the most part I locked my memory in at 1:1.. set the timings to stock and left it for now.. I don't know the value of running my system at a 5:4 with maybe the memory at 500x2 for their stock 1k but it might be worth it.. I'd like to compare the differences between the faster mhz and asynchronous mode and the slower mhz, but with better timings and 1:1... I have no personal experience with it so hsould be interesting to figure it all out.
__________________ EVGA750i FTW|Q6600@3.0 1.30v|4gig Mushkin Redline 5-5-5-12 @ 10??mhz ?.??v|SLI 2xEVGA 8800GT Akimbo 720/2k|Corsair TX750|Antec 900|Samsung 226BW 22" LCD| WD Caviar 320gb SE16|WD Caviar 750gb Black Edition SE32|Vista 64 |
| 3.0ghz FSB 1.25v (+.5 from stock), Vcore 1.275v 2hours+ Stable in Prime95. No errors yet. 41-48°c across all cores after those two hours too! Going to drop it again, and test for 45 minutes until I get an error. Still 1:1 with my memory at 1.8v/333x2 for 667mhz. Eventually when I find a sweet spot for my vcore that I feel is good I'll push 24 and 48 hour iterations.
| Vcore 1.19v stable 5+hours in prime95. I'm going to drop it to 1.16-ish volts over the next few hours and run for 10 or more hours tonight. We'll see what I get! 38°-42°c full load after those 5 hours! YOIKES! this Q6600 rocks! If this keeps going lower I might go for 3.2+ ghz
| No dice! It'll post and boot windows below 1.1875v but it fails almost instantly upon running prime95 and windows even reports recovering from a fatal error. It may very well turn out to be sketchy at 1.1875v so I'm going to push 10 hours at this voltage, if it errors around here - which I'm expecting it will; I'm fairly certain I can hold steady at 1.193v. Still not bad concidering how damn cool I'll be at 1.193v. if I can get it to hold for 24 hours at that eventually; I'm going to push 3.2ghz for the hell of it.. I think I could easily do that below 1.3v on this system for sure. I guess eventually I'll compile all my steps (I've logged it all) into a little guide with info for everyone.
__________________ EVGA750i FTW|Q6600@3.0 1.30v|4gig Mushkin Redline 5-5-5-12 @ 10??mhz ?.??v|SLI 2xEVGA 8800GT Akimbo 720/2k|Corsair TX750|Antec 900|Samsung 226BW 22" LCD| WD Caviar 320gb SE16|WD Caviar 750gb Black Edition SE32|Vista 64 Last edited by encorp : June 3, 2008 at 06:29 PM. |
| You're going the wrong way... oc'ing is up, with no limit! Seriously, 3.0G with such low voltage is great - shows a lot of potential for the chip. Once you're comfortable with your oc, save your BIOS settings and start upping that FSB. I use OCCT (Download - OCCT Website english) to test my rigs; usually a 30 min. custom test shows stability. Then I raise the FSB again, with Vcore if needed. To give you a rough idea, I managed 4.1Ghz with one of my Q6600s (Vcore was 1.6V), and that same Quad was stable for folding at 3.8GHz (Vcore 1.525V) - all under water, mind you. sswilson did the same, but with less Vcore. With the Q6600, you're fine as long as it doesn't pass 60C under load and you don't give it more than 1.5V Vcore. I believe you'll reach the thermal limit before the voltage limit if you're using air.
__________________ Asus P5E Deluxe X48 (flashed to Rampage Formula) - E8400 @ 4.2GHz - Corsair HX1000W - Raptor 74Gb - Mushkin XP2-8000 2x2Gb - BFG GTX280 - Wc'ing: PA120.2 w/Panaflos, Stinger V8 - Lian-Li PC-V1000 Gigabyte GA-EP45-DS3L - Q6600 @ 3.0GHz - Corsair HX620W - Raptor 37Gb - Mushkin EM2-6400 2x1Gb - BFG GTX280 - IFX-14 - Antec Sonata II |
| Quote:
I'm really hoping that's a typo..................
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW DFI P965-S Dark / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| HAHAHA oh yess it is!!! fixed.
| Quote:
I did have an error after 5 hours on 1.1875 tho, so I'm at 1.193* and i'll run more tests tomorrow,, I'm worried I'll need to be above 1.2 though, we'll see after a 24 hour run. I'll try out OCCT and see what it's like! Thanks a bunch!
__________________ EVGA750i FTW|Q6600@3.0 1.30v|4gig Mushkin Redline 5-5-5-12 @ 10??mhz ?.??v|SLI 2xEVGA 8800GT Akimbo 720/2k|Corsair TX750|Antec 900|Samsung 226BW 22" LCD| WD Caviar 320gb SE16|WD Caviar 750gb Black Edition SE32|Vista 64 Last edited by encorp : June 3, 2008 at 08:10 PM. |
| Quote:
Great to hear that you're enjoying this. Too many folks (myself included) jump right to the max OC they can get without savouring the process.
| Thread Tools | Search this Thread |
| Display Modes | |
