Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
  #21 (permalink)
Old May 10, 2008, 07:41 PM
encorp's Avatar
Level up: 94% Level up: 94% Level up: 94%
Level: 13 - 30 points to level up
Originally Posted by sswilson View Post
Sounds about right, but don't let those kinds of temps stop you from doing some mild OC work with it... :)
You'll be able to bump it up some without any Vcore which shouldn't affect temperatures all that much. At the very least that'll tell you what the chip is capable of on stock volts.
Well I f'ed up and forgot to order some good thermal paste with my order too so I got some coming with my true, that should help, all the fans are on low as well, I'm sure I could push them to cool better if need be :)
Can't wait to get oc'ing this thing.
One question actually, is it worth oc'ing my video card? I have the EVGA Akimbo SC - it is factory oc'd to 720/2k - can you get much more out of these?
EVGA750i FTW|Q6600@3.0 1.30v|4gig Mushkin Redline 5-5-5-12 @ 10??mhz ?.??v|SLI 2xEVGA 8800GT Akimbo 720/2k|Corsair TX750|Antec 900|Samsung 226BW 22" LCD| WD Caviar 320gb SE16|WD Caviar 750gb Black Edition SE32|Vista 64
  #22 (permalink)
Old May 10, 2008, 08:45 PM
BALISTX's Avatar
Level up: 14% Level up: 14% Level up: 14%
Level: 21 - 1,045 points to level up
If you do another order I would pick up some AC MX-2 thermal paste.
- Rigless
[Heatware]
  #23 (permalink)
Old May 10, 2008, 08:59 PM
encorp's Avatar
That's actually what I ended up ordering with my TRUE :D
  #24 (permalink)
Old May 10, 2008, 09:02 PM
BALISTX's Avatar
Personally I think it's the best stuff on the market. Once your TRUE comes in you will be all set. My AC Freezer 7 Pro came with MX-2 installed on it.
- Rigless
[Heatware]
  #25 (permalink)
Old May 10, 2008, 09:20 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
FYI, NONE of Arctic Cooling's current CPU coolers come with MX-2 installed. This is right from the mouth of AC themselves.
  #26 (permalink)
Old May 10, 2008, 09:21 PM
MAC MAC is online now
News Editor
Originally Posted by encorp View Post
Haha well here is my info from my Q6600 GO:FPO/Batch#: L729B243
Wow, that's an OLD chip, you got lucky
Q6600's made in 2008 are having trouble breaking 3.2Ghz with reasonable voltage.
  #27 (permalink)
Old May 10, 2008, 09:43 PM
BALISTX's Avatar
SKY: According to AC's website it says it comes with Pre-applied MX-1 / MX-2 Paste and from what I have heard the newer ones come with MX-2 paste pre-applied.
Arctic Cooling
- Rigless
[Heatware]
  #28 (permalink)
Old May 10, 2008, 10:09 PM
encorp's Avatar
Apparently, according to "posts" on NCIX under the Scythe Katana 2 i have, it also comes with a packet of it.. but I don't know what to look for so I cant tell you what I have, is or was lol.
Haha well good to know, mine was sitting on a shelf down at intel for awhile so maybe thats why lol
  #29 (permalink)
Old May 11, 2008, 08:46 AM
encorp's Avatar
So I was running some tests before I went and started oc'ing next week and I notice today that the cores seem to be running hotter. My room is fairly chilly, I literally have floor to ceiling window with about 4 feet of it open to outside and a fan in the room. For me, not the comp lol. It is about 15°c to 20°c in here all the time at this time of year, I rarely if ever close windows in my place (GF hates it tho! LOL)
Anyways
Is this cause for concern:
  #30 (permalink)
Old May 11, 2008, 08:57 AM
encorp's Avatar
Hmm, this is AFTER I removed the side panel and then ran prime95
Forum Jump
Search this Thread:
Advanced Search
