Old May 28, 2014, 11:12 AM
TTC TTC is offline
Default Question about manual voltgage and idle down
Hey fellas, so I have my pc oc'd at 1.22v at 4.2 and its stable. I also have it at 4900 stable at 1.4v.
Question is now it wont clock down the speed. Its stuck at 4900 instead of lowering to 1600. Is this due to using manual instead of offset on my asus z877 motherboard.
2500k
asus p9z77 lk
Old May 28, 2014, 12:03 PM
Bond007's Avatar
eist or speed step (I am pretty sure) are the settings is BIOS that allow CPU to downclock to 1600mhz at idle.
Manual voltage will force voltage to stay at the fixed value. If you want voltage to lower with load you have to use voltage offset (goes by various names).
Thats how it works on my gigabyte board anyway.
Desktop: Antec Three Hundred, Z77-D3H, 3570K undervolt @4.1ghz with Zalman Optima Cooler, Corsair Vengeance 2x4gb@1866mhz, HD 6950(unlocked shaders and OC'd), Bitfenix Fury 750w, WD Black 1TB, Intel 530 120GB
Old May 28, 2014, 03:27 PM
TTC TTC is offline
Does it harm anything if it's stuck at 4.9 with no down clock
Old May 28, 2014, 03:31 PM
Bond007's Avatar
well....not really. I can't say its going to make it have a short life, but it definitely would be harder on the CPU in the long run, while also using more power.
Old May 28, 2014, 04:26 PM
TTC TTC is offline
Yea, I usually only keep cpus for 2 years max lol. I'm sure its fine.
Old June 10, 2014, 07:05 AM
you might also look at the windows power options, the minimum processor policy affects how it downclocks
GEN-9010 User Manual leppy99 Guides & How-to's 0 March 3, 2012 12:24 AM
Better GPU Performance with Fan Speed Set to Manual? PockyMaster Video Cards 10 November 6, 2011 09:45 PM
Something wrong with my lab manual? BrianHanna Off Topic 9 January 26, 2011 11:54 PM
Civilization V pdf Manual Available ipaine Gaming 21 September 21, 2010 10:49 AM
Manual Super Pi mattydies Press Releases & Tech News 0 June 17, 2010 02:30 AM
