Old May 18, 2014, 06:24 PM
b1lk1's Avatar
Default Opteron 165 Fun with relics
I always had fun overclocking S939, decided to start buying whatever I can find 939 and DDR too. Amazing how much sturdier DDR is that stuff almost never dies. I even tracked down a pair of OCZ VX PC4000 512MB sticks, if I can get an OCZ DDR booster I could really go for it.
So far it's running 3.05GHz @ around 67C full load using a Zalman CPMS9000. I really need better cooling, it's hard to find now. Gonna de-lid and water cool it ASAP.
I'll post up some pics in a few days.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old May 18, 2014, 06:55 PM
sswilson's Avatar
That's essentially the same chip as the 3700 isn't it? If so, you've already passed the DFI-Street 3G club requirements. The DDR sticks are probably a big part of that.... been a while since we had a platform that could be held back by lower clocked mem.
Cut my OC teeth on S939. Spent many a night tweaking one or two mem settings and then benching to see if it was an improvement or not. :)
Old May 18, 2014, 07:03 PM
ZZLEE's Avatar
I have some DDR3 In 6-7-6 6GB 1600. drop then into a system to push fore CPU overclocks. Fast tight memory makes a big difference on my Intel CPU also.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 18, 2014, 07:23 PM
sswilson's Avatar
For benchmarks yes, but because of unlocked processors, memory these days typically isn't going to be the limiting factor in how high you can clock your processor. Back in the PC3200 days it was fairly easy to hit a wall unless you had some memory that was willing to clock well above its rated specs.
Old May 18, 2014, 08:01 PM
S939 with BH5 and UTT was such a great combo. I really miss those days.
heatware
Old May 19, 2014, 10:20 AM
Coach's Avatar
I still have a opty 165 with an ASUS A8N32-SLI in use. It has been running since I built it brand new. 2.7Ghz is all I could ever manage from that chip...
Old May 19, 2014, 11:20 AM
sswilson's Avatar
Hrmmmm... my memory isn't what it used to be... opty 165 is a dual core which makes the 3G+ achievement all the more impressive.
Old May 19, 2014, 03:30 PM
Coach's Avatar
If your memory is going then you may not remember how good your memory was to begin with.
Old May 21, 2014, 04:01 PM
b1lk1's Avatar
S939 needs really good ram to shine, especially when cranking up the HTT. Right now, I am within 5 MHz HTT of instability (mostly due to heat).
I need to get some good water gear, but not until I move to Lindsay next week.
Old May 21, 2014, 05:07 PM
Wow. I actually own a 165 opty that I delidded years ago and it still works. Just a heads up, you're going to lose some torque on the cpu mount because of the missing 1/8" inch from the IHS. No biggy though as the direct contact somewhat compensates for that. You also have to uber carefull when mounting the block to avoid cracking or damaging the chip. A shim is recommended.
Don't expect much more than the 3+ ghz you currently have. Its more a memory thing. With that being said, its easy to damage the mem controller on the chip. I'm actually gonna repurpose the old girl for maybe a pf sense box. Power consumption shouldn't be too harsh. (100 watts running 24/7; Ya right)
Opteron C32 Server Soullessone21 Price Check 0 March 19, 2012 12:18 PM
Opteron 146 system hdvision Price Check 2 February 12, 2012 02:09 AM
[WTB] WTB A8N SLI Board and opteron cpu tyreman Buy/Sell & Trade 0 December 29, 2008 04:08 PM
Opteron Experiment xrmarcis CPU's and Motherboards 8 September 24, 2007 12:44 PM
opteron 165 will not POST magictorch Troubleshooting 13 April 9, 2007 02:34 PM
