Old May 4, 2008, 08:09 PM
BALISTX's Avatar
Default E2140 Oc
I'm in the process of OCing my E2140. I currently have it at 2.4GHz and running Orthos blend FFT stress test. My temps to me seem a little high for load 52C is the max I've seen so far. I've been running it for 5mins.
I have a AC7 Pro for a HSF and I'm wondering if I may have to reseat it. I have not up the voltage and in the BIOS it's showing it at 1.32.
I am running a Gigabyte P35-DS3L rev2.0 BIOS F7.
For cooling I have 3 120mm case fans blowing exhaust I don't have any intake fans connected yet. I have a CM690 case. Ambient temp is around 17 degrees.
My goal is to get it to 2.8-3.0GHz on air.
Heatware
HWBOT
Old May 4, 2008, 08:25 PM
BALISTX's Avatar
Default UPDATE
I now have it at 2.6GHz with a vcore of 1.35 in the BIOS (1.30) in CPUZ. I'm running Orthos at the moment and temps have peaked to 55C for both cores after 5 mins.
Heatware
HWBOT
Old May 4, 2008, 08:49 PM
sswilson's Avatar
Did you try a re-seat of the cooler? I'll usually do two or three when I get either a new cpu or cooler just to satisfy myself that I've got a decent mount.
Old May 4, 2008, 08:53 PM
BALISTX's Avatar
I've reseated it twice when I first installed everything. So far my temps haven't peaked past 56C and it's been running for 32 mins.
Heatware
HWBOT
Old May 5, 2008, 04:06 AM
3.0charlie's Avatar
So my old-and-trusty E2140 is back at work? That's great!
With an ambiant temp so low, the load temp shouldn't be that high. I'm pretty sure that the CPU does not need a lap job (temps were fine with either my AC7 Pro or the Apogee GT), but have you checked the HSF?
Also I would play with your fans - I don't think going with a full blown exhaust setup is the way to go. That chip will need some fresh air to keep cool.
Hydro-Quebec is salivating...
Old May 5, 2008, 06:13 AM
BALISTX's Avatar
Yea I'm going to play with the fans I might put the top two as intake for now. The ambient temp in the room was 20C I was mistaken with the 17C. I ran Orthos for 8 hours and the highest temp was 57C. I'm going to try reseating the heatsink at some point this week. I'm sure once I get the fans setup with some intake it will run cooler.
Heatware
HWBOT
Old May 5, 2008, 09:41 AM
You canceled the bbq to overclock your computer?? You are a hardware canuck?
Old May 5, 2008, 04:37 PM
3.0charlie's Avatar
Play with the setup - I know that chip is a cool-running one.
Old May 5, 2008, 05:26 PM
BALISTX's Avatar
I think I will hold off for now. I'm gonna order another 3 more two more fans for intake and hook up the front one for intake as soon as I get a 3 pin to molex adapter. Plus I'll be adding my 40mm Scythe Kaze fan to the NB.
Heatware
HWBOT
