Old March 7, 2014, 11:40 AM
Shadowarez's Avatar
Default Beast Overclocked.
heres the system under Stress, hows the Temps look to you guys?
Old March 13, 2014, 11:02 AM
is this a 3930k? how are your load temps so low for 1.4v?
Old March 13, 2014, 06:26 PM
ZZLEE's Avatar
See If you can drop the volts and keep the overclock.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 13, 2014, 06:50 PM
Shadowarez's Avatar
Its a 4960X yeah ill upload the actual volts that was from its first start up Oc I put the Vcore down to 1.39 since and upped the Oc to 4.7ghz ill put Em up tonight.
Old March 13, 2014, 06:55 PM
Shadowarez's Avatar
Default oc
Heres what my Oc looks like in ai suite so far. Ill try get some bios screen shots.
Old March 13, 2014, 06:56 PM
Shadowarez's Avatar
I ran crysis 1 then 3 to get a decent load for gaming temps. Next is prime temps.
Old March 13, 2014, 07:00 PM
ZZLEE's Avatar
Try a Vantage run.
still quit a taxing bench.
Old March 13, 2014, 07:11 PM
Shadowarez's Avatar
Yeah I will need help tuning Voltages once I get some bios shots. I had this chip at 5Ghz but wasnt completely stable.
Old March 13, 2014, 09:38 PM
Shadowarez's Avatar
This is cooled by my Temporary Clc Zalman Reserator Max 3. Its a surprisingly good cooler. Especially for the Oc im running I seen the Vcore on cpu run upto 1.48 and didnt reach 45c.
That was in the beginning iv since deciphered the mix of giudes on ROG fourm and dropped Vcore down to 1.39 iv yet to fully decipher there explanation of offset Ocing.
Old March 17, 2014, 07:01 AM
Shadowarez's Avatar
Default voltage update
dropped voltage even more down from 1.42 to 1.3. tried upping multi didnt wanna stay stable,
My WaterCooling Beast bautisj Water Cooling 6 October 2, 2010 11:06 PM
$1500 BEAST:Need HELP!!! Lavitz New Builds 11 October 28, 2009 08:15 AM
Hopefully a beast. majestikk New Builds 9 August 11, 2009 07:23 AM
Tearing apart a beast Lpfan4ever Case Mods, Worklog & Gallery 0 May 9, 2009 12:28 AM
The Beast (not really) in all its glory. Soultribunal Case Mods, Worklog & Gallery 11 December 11, 2008 08:32 PM
