Old February 11, 2014, 01:45 AM
Shadowarez's Avatar
Default phase changer under $1000
What do you guys think Little Devil this would make a overclock nice and stable.
a steady 300W of dissipation at -30 C. Normal temperatures for this unit at Windows is -38 to -45C depending on CPU usage and heatload
Old February 11, 2014, 02:30 AM
Unless your doing some serious overclocking simply not worth it.
Get a inexpensive tec unit, power supply and a AIO and call it a day.
Old February 11, 2014, 02:45 AM
Shadowarez's Avatar
Well figured I will be using a H320 Swiftech with 6 Noctuas this would be a extreme upgrade in cooling lol.
Old February 11, 2014, 02:59 AM
Extreme? No.
Crazy yes.
Old February 11, 2014, 04:19 AM
Shadowarez's Avatar
Then it's perfect lol. But was looking around for last bit of modding supplies and found that.
Old February 11, 2014, 07:14 AM
Dead Things's Avatar
In my opinion, SS is not really a viable alternative for normal 24/7 cooling due to the preventative measures that need to be taken against condensation. It is, however, a great way to introduce yourself to sub-zero competitive overclocking and benchmarking.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old February 11, 2014, 09:11 AM
KaptCrunch's Avatar
along with noise and hydro not worth it for a daily runner
Old February 11, 2014, 02:38 PM
No love for the phase! It probably isn't practical for cooling 24/7 but since when is spending a $1000 on a cooling solution practical. If you want the very best cooling to achieve the very best overclock for 24/7 the only option is phase cooling. Its noisy, uses tons of hydro, and you definitely should provide waterproof insulation to protect your hardware unless you are operating in a very low humidity enviroment. If you are using any modern quad core Intel/AMD chip you shouldn't consider TEC as it just can't keep up or maintain temperatures at any serious amount of overclock.
If you are serious about benching, then phase is definitely a giant bonus!
Old February 11, 2014, 02:43 PM
Uhm.. come again?
I had my i5 2500k under tec and was running @ 4.7 with idle temps around 15-16 idle and 25 under load. How is that now able to maintain?
Old February 11, 2014, 03:38 PM
KaptCrunch's Avatar
gee you missed the pot of dice
news flash a TEC can run 7/24 and with good results with 4-12c less then ambient depends on module used
same insulation needed for phase change
Alphacool NexXxoS UT60 Full Copper 360 vs TFC X-Changer Triple Radiator 360. goldry Water Cooling 2 February 11, 2012 11:34 AM
[WTB] Feser X-Changer 240 vohiep84 Buy/Sell & Trade 0 December 1, 2010 09:05 AM
Feser Done, No More X-Changer AmuseMe Press Releases & Tech News 11 May 8, 2010 09:35 PM
Wallpaper changer? RainMaker O/S's, Drivers & General Software 3 March 16, 2009 08:48 PM
X-fi Mode changer app Now compatible with Prelude Robscix Audio 0 November 13, 2007 12:42 PM
