Old February 11, 2014, 09:42 PM
Apparently, there are differing opinions on what is a good temperature for overclocking. I'm not saying that TEC can't get close to or even dip under ambient temperatures, if you are going to get extreme TEC doesn't cut it. Phase will hold -30C for 24/7 and if you want to get real crazy, a cascade holds -80 to -100C but you double the noise and make it almost impossible to fit into a case of any practical size.
Also a 2500K still doesn't run near as hot as a full 8-thread Ivy or Haswell processor, never mind a hex core.
I must have missed the pot, or you could have best of both worlds!
Old February 11, 2014, 10:26 PM
LionRed's Avatar
I use to run Phase 24/7 back in 2009....damn 5 yrs ago!
Was fun prepping the MB and CPU for it. Was a nice learning experience.
Lotsa this -
Vaseline in the CPU socket.....use gun cleaner to clean the cpu socket full of Vaseline. Was the only thing that worked really well at cleaning it out. Don't let the Vaseline touch the artist eraser....it gets messy if you do. Eraser virtually turns to goo.
But perhaps things have changed since I last did this.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old February 24, 2014, 09:24 PM
Shadowarez's Avatar
This looks like a wicked project idea then. When this comp I have becomes a dinosaur ill have to turn it into a experiment and try this.
Alphacool NexXxoS UT60 Full Copper 360 vs TFC X-Changer Triple Radiator 360. goldry Water Cooling 2 February 11, 2012 11:34 AM
[WTB] Feser X-Changer 240 vohiep84 Buy/Sell & Trade 0 December 1, 2010 09:05 AM
Feser Done, No More X-Changer AmuseMe Press Releases & Tech News 11 May 8, 2010 09:35 PM
Wallpaper changer? RainMaker O/S's, Drivers & General Software 3 March 16, 2009 08:48 PM
X-fi Mode changer app Now compatible with Prelude Robscix Audio 0 November 13, 2007 12:42 PM
