Old February 8, 2014, 05:37 AM
Gregole's Avatar
Default Temperature Question
I was recently using prime95 to check my 2600k' temperature @ 4.7ghz. I was wondering what is the normal temperature when of 2600k @ 4.7ghz on load?
Ambient Temperature: 22*C according to phone S4 (not sure if accurate)
Core 0-3: between 60*C and 70*C (core 1&2 higher than core 0&3)
Using a H100 cooler pulling air from top of case.
Tower is in an enclosed space around the side and top
The Top and Side has about 3 inches of breathing room.
Now Playing. . .
Old February 8, 2014, 12:05 PM
SugarJ's Avatar
The problem is there's no such thing as normal when OC'ing due to the wide variety of cooling options.
I prefer not to push my CPU temps past 75, but that's just me.
Old February 25, 2014, 01:59 PM
75 is the highest you wanna go
Old February 25, 2014, 07:30 PM
basically, you're fine, don't worry too much about core fluctuations.
XFX 6970 Temperature Question LaMig Video Cards 11 October 22, 2011 11:30 PM
Temperature question ( which temperature do I go by? Shadowmeph Overclocking, Tweaking and Benchmarking 3 August 19, 2011 01:00 PM
[Question] Temperature gaha885 Overclocking, Tweaking and Benchmarking 11 November 12, 2010 10:29 AM
Core i7 temperature question xXxRithxXx CPU's and Motherboards 19 June 25, 2009 02:44 PM
Overclocking temperature question CORE Overclocking, Tweaking and Benchmarking 6 May 22, 2009 01:44 PM
