Old December 23, 2013, 05:37 PM
sswilson's Avatar
Default Source for legit High Def media files?
I've been asked to check out the playback on a mITX dual core Celeron motherboard, but since I don't rip movies I don't have a clue where to begin.
Is there a source for legit HD content I could download, and/or a primer on testing playback? I'm assuming that there must be a worst case scenario WRT resolution + audio playback decoding which would hopefully make success or failure pretty obvious, but if not I'd appreciate being pointed towards any kind of quick(ish) HD content for dummies type FAQ.
Thanks in advance.
Old December 23, 2013, 05:49 PM
Movie trailers?
However, you'll probably want to test full HD, non-compressed files because if you can run those then you can run anything, granted everything is groovy on the software side of things. Not sure where you could find those kind of files though.
EDIT: Looks like Supa has you covered.
Old December 23, 2013, 05:51 PM
supaflyx3's Avatar
This is what I use:
Big Buck Bunny
1080P/4k etc
Old December 23, 2013, 05:52 PM
sswilson's Avatar
Originally Posted by YukonTrooper View Post
Movie trailers?
I honestly don't know... are high def movie trailers available at 1080p + whatever kind of audio that would be taxing on a system?
I'll have a look to see what I can find.
Old December 23, 2013, 05:56 PM
sswilson's Avatar
Originally Posted by supaflyx3 View Post
This is what I use:
Big Buck Bunny
1080P/4k etc
Ok, cool.... Big Buck Bunny Download So what format would be the most common, H.264? If so, would a quick google search come up with a player/codec pack for it?
Again, thanks in advance... I honestly have no idea at all and am trying to save myself from having to get too deep into studying the process just to do some form of benchmarking. :)
edit: Downloading the 1080p mpg4 avi file... would that be the best choice? And you wouldn't by any chance be pulling an old man's leg would you??? I'm not going to end up looking at goat pron am I??? ;)
Old December 23, 2013, 06:00 PM
3.0charlie's Avatar
Yup, HD trailers are best for this. I've used a few to evaluate Surround Sound / HDTV setups in Aircraft. Batman The Dark Knight was my favorite. You can d/l it here: http://www.fileplanet.com/183599/dow...ht-Trailer-(HD)
Hydro-Quebec is salivating...
Old December 23, 2013, 06:04 PM
sswilson's Avatar
Yup, HD trailers are best for this. I've used a few to evaluate Surround Sound / HDTV setups in Aircraft. Batman The Dark Knight was my favorite. You can d/l it here: The Dark Knight Trailer (HD)
Hrmmmm.... thanks, but for some reason that link is taking me to a 404 message on IGN.........
That said... am I on the right track WRT using the mp4 files?
edit... NVM for some reason it's working now. Thanks. (ahhhhh the evil quicktime format.... ;) ).
Old December 23, 2013, 06:50 PM
sswilson's Avatar
Sorry for the quick bump but I wanted to say thanks and that I think I've got it up and running (including downloading a codec pack and reading the install process verrrrrryyyyyyy carefully to avoid installing crapware... :) ). Now to wait for Christmas to get the motherboard in to test. :)
Old December 23, 2013, 07:50 PM
Why install a codec pack for? Just install VLC or XBMC and they'll decode them on their own.
Old December 24, 2013, 05:57 AM
sswilson's Avatar
I already had xbmc installed, and had given it a try, but didn't realize that the screeching audio was due to the audio being set to digital as opposed to analog. :)
Help! Shared folder not updating new media files Evylldemon Troubleshooting 9 October 4, 2013 03:23 PM
Patriot Memory Refreshes High-Definition Media Player FiXT Press Releases & Tech News 1 November 8, 2010 02:34 PM
all .mkv files on my PC and WD TV media play very low volume Shadowmeph Off Topic 19 August 22, 2010 08:36 PM
Business High Def Media Computer Build - Need your Help & Opinions! g-mess1 New Builds 11 December 30, 2009 05:09 PM
Laptop Backup - Media files matsta31 Networking 6 November 23, 2009 01:45 PM
