Old December 15, 2013, 04:56 PM
Default overclocking help!
looking for some guidance to overclock on a Gigabyte Z68x-ud3h-B3 with a 2500k.
i havent done overclocking since my e8500. so im not sure where to start.
thanks!
Old December 15, 2013, 05:25 PM
Shadowmeph's Avatar
I usually usse the Auto function and then go from there to try to get higher
Old December 15, 2013, 05:34 PM
G777's Avatar
Give this guide a read through The ULTIMATE Sandy Bridge OC Guide + P67A-UD7 Performance Review
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old December 15, 2013, 06:24 PM
thanks!
Ensure the ram voltages and timings are set properly.
Then just start bumping up the multiplier. Use Intel Burn Test (IntelBurnTest - The new stress-testing program) to make sure the CPU is stable.
Just don't jump the multiplier up to much at a time.. Oh and unless you have an aftermarket cooler don't bother at all.
Old December 15, 2013, 09:23 PM
runniong a corsair h110 on my 2500k atm. and i will try what's been suggested so far.
Old December 16, 2013, 07:53 AM
fishingfanatic's Avatar
Smile Overclocking help
What they said. If you're still having trouble, go to the ROG site, it might give you some insight.
I don't know if Gigabyte has a help forum, you could try that. Try to google it as well.
Unless you're going for 5 Ghz, as mentioned the multiplier and bclk r the 1st things to play with.
Hope we helped!.
FF
GTX 480 Overclocking ImmaPC Overclocking, Tweaking and Benchmarking 24 March 13, 2011 06:36 AM
GTX 580 overclocking ToXic Video Cards 6 December 18, 2010 01:09 PM
GTX 460 Overclocking jcmaz Overclocking, Tweaking and Benchmarking 2 December 3, 2010 07:33 AM
Overclocking Ram ToXic RAM 0 November 22, 2010 10:02 PM
Needs some help overclocking lanken123 Overclocking, Tweaking and Benchmarking 0 April 21, 2009 11:51 AM
