Old November 8, 2013, 10:11 PM
rjbarker's Avatar
Default H320 @ 4.9 Ghz
Honestly guys I cannot remember if I posted these numbers or not......call it a "Bob Zone" moment if I did...and no Rum tonight Soul...
Anyhow, my present 4.9 Ghz OC'd 3930K, this is my 24/7 use guys....quick screen capture after 20 passes LinX..Max Temps maybe legible, if not:
74c - 70c - 65c - 68c - 72c - 73c across all 6 cores. - the Swiftech AIO 320 is awesome, wonder how much these temps would come down with a good custom loop
vcore +.09v offset - works out to be around 1.406v under full load...1.389v at desktop when not downclocked to 1.2Ghz. At 1.2 ghz idle sitting at a nice .8656v ;)
I did try up to 5Ghz a few weeks ago but large vcore seemed to be required, as jumps tp 1.46v....this 4.9 Ghz seems to be the sweet spot for this Chip
Cheers
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 9, 2013, 12:13 AM
KaptCrunch's Avatar
I get a cooler TJ Max then you and my temps are higher
cpu Hex 4930k rad 120
Old November 9, 2013, 12:56 AM
rjbarker's Avatar
My TJ Max Temp is 91c...yours is 95c ;) Makes sense.....considering your CPU is showing 3900 Mhz and mine is 1500 Mhz (stepped down)
MARK 11: 32.530
Corsair h100i vs Swiftech H320 rjbarker Water Cooling 23 February 22, 2014 11:30 AM
Completed Procyon II - 900D n Swiftech H320 rjbarker Case Mods, Worklog & Gallery 4 October 18, 2013 12:54 PM
H320 pump noise Coach Water Cooling 4 September 17, 2013 04:16 PM
OC'ing 3930K n Swiftech H320 rjbarker Overclocking, Tweaking and Benchmarking 6 September 14, 2013 04:10 PM
