Old October 25, 2013, 10:55 PM
rjbarker's Avatar
Default Procyon II @ 5Ghz Tri 680 OC'd - Benchmarks
Started fartin around again this evening and decided to "push" the HW a little bit further, grabbed a few Benchmarks.
Lookin at that HwBot Country competition, joined the HWC Team and started playing, unfortunately my A.D.D kicked in while I was trying to figure out how to post wPrime scores to HwBot.n here, needs me to focus more......
Okay the 3930K @ 5 Ghz (100 x 50 ) - a little bit of tweaking from 4.9 Ghz (Rock Stable):
- Upped my LL Calibration from Medium to High
- Upped vCore Offset from +.090v to +.125v ( Vcore Load from 1.39v to 1.46v )
LinX under load , Max Core temp was 82c on the hottest Core and around 70c on the coolest (not bad really considering 5 Ghz and 1.46v ), unfortunately I only got through 7 passes LinX, then "error" (no BSOD so a good sign, a little more tweaking...maybe some more vTT and a tad more vCore or try Non Offset Mode).170 GFlops at 4,000+ Memory useage.....but got thru a number of other Benches!
3DMK11 - 25,090
NVIDIA GeForce GTX 680 video card benchmark result - Intel Core i7-3930K Processor,ASUSTeK COMPUTER INC. RAMPAGE IV EXTREME
3D Firestrike - 16,130
Cinebench ver11.5 - 14.42 Pts
wPrime 1024M - 105.486 sec
wPrime 32M - 3.905 sec
3 X GTX 680 Classy's @ Core: 1267 Mhz / 3208 Mhz
331.58 WHQL
Evga Precision 4.2.1
In Precision - 120% Power target - +79 mhz Core / +204 Mhz Memory
Anyhoo, but all I got up then my A.D.D kicked in once more....playing with the dog now
Cheers guys..
Firestrike Extreme: 21.452
MARK 11: 32.530
Old October 26, 2013, 05:10 PM
Sounds like a pretty good setup to try for the first stage of the Country Cup. Your score is certainly closing in on the #1 spot in that category, with that setup at least.
Old October 26, 2013, 06:10 PM
sswilson's Avatar
Hehehe... without being able to see that it's 3 cards in tri-sli that's some major hardware pron right there..... ;)
Old October 27, 2013, 09:36 AM
rjbarker's Avatar
I know my GPU's are pretty much maxes out n on the border of "will I get through this run".....the Cores anyhow, maybe able to squeeze a tad more out if the Memory.
As for the 3930k, my next Benchmark runs Ill see if I can get 5.2 Ghz , with 1.5v - 1.55v, Works better if I've had a beers ;)
MARK 11: 32.530
Completed Procyon II - 900D n Swiftech H320 rjbarker Case Mods, Worklog & Gallery 4 October 18, 2013 12:54 PM
Procyon II - Last Upgrades 2013 rjbarker New Builds 3 September 10, 2013 10:29 PM
Completed Procyon II -Reborn w RIVE, 3930K & 16GB Corsair Dominator 1866 rjbarker Case Mods, Worklog & Gallery 10 May 17, 2013 04:42 PM
Procyon Re-Born ...Not Really..a Face Lift!! rjbarker New Builds 4 April 28, 2013 07:25 PM
Procyon Is ALL Classy ;) rjbarker Video Cards 7 January 29, 2012 10:26 PM
