  #61 (permalink)
Old November 22, 2013, 07:00 PM
fishingfanatic's Avatar
Smile Country Cup
Well I finally figured out some better ocing.
Saved a few results which I'll be submitting, I hope.
Some interesting results when looking at xfire compared to tri fire!
FF
  #62 (permalink)
Old November 23, 2013, 12:46 PM
Smile Country Cup
Ok I ran my 570. B4 I try to submit it, I thought I would check here 1st to make sure I've done it properly.
I believe there's a 570 Cloudgate for stage 2 and a Super pi with the cpu at 4.000 Ghz and a titan 4 stage 8.
Plz let me know so I can submit it if everything's ok or rerun the benchmarks....
FF
  #63 (permalink)
Old November 23, 2013, 01:46 PM
You need the background from the competition in order to submit the screenshots. Also you will need two instances of CPUz open, one that has the CPU tab open and the second one that has the Memory tab open. So, the SuperPi screens just need the two CPUz open and the video card benchmarks need the two CPUz and a GPUz open. Also don't cover the settings you used for 3dmark03, make sure especially the screen resolution is visible (I think that is the reason for the rule) and you have to open the DETAILS tab of the score box so that each of the stages score can be seen.
Here is the one I submitted for 3dMark03 for example:
Hope that helps!
And remember SLMGR is your friend
  #64 (permalink)
Old November 23, 2013, 02:00 PM
Smile Country Cup
Holy cr#p.
Is this a pita or what, just to submit scores...?
Sorry folks, rant over...for now hehehe.
FF
At least I only have a cpl tests to run over. Damn, doing something I enjoy,...wtf is this world coming to?
  #65 (permalink)
Old November 23, 2013, 02:43 PM
Doing your country proud can be tough work!
  #66 (permalink)
Old November 23, 2013, 03:41 PM
Originally Posted by fishingfanatic View Post
Holy cr#p.
FF
cheaters are everywhere sadly
on topic
i can provide some scores to help my country, but i slacked on hardware so nothing recent
stage4 i have an i3 in my htpc
stage7 980x or 2500k with gtx580
stage8 8m30sec first try
  #67 (permalink)
Old November 23, 2013, 04:17 PM
Default Country Cup
Ok big guy, I think I got it right this time. Should probabaly read a bit more next time...
FF
I just realized the settings are covered up..
  #68 (permalink)
Old November 23, 2013, 09:25 PM
Smile Country Cup
Ok I think it's all good to go now.
After a good night's sleep I'll read up on how to enter.
FF
Hey even though the 7990s are tops do we still submit a lower score anyway?
I do have the 3 R9 280xes for tri fire and the 580s for sli as well. Tempted to put the ultra with the 2 reference, though I doubt they will, or at least run well, and even ocing them to match as close as possible would take some work. A 1200 w psu is plenty, and just enough pcie for the 3 plug card.
Don't think we do but thought I would ask, just too tired to read atm.
B4 I forget, GO CANADA GO!!!
FF
  #69 (permalink)
Old November 23, 2013, 09:52 PM
Default Country Cup
Do we submit other scores even though there are higher ones.
I don't have the monstrous scores some folks do, and congrats folks, but it's not too bad.
AMD Radeon R9 280X video card benchmark result - Intel Core i7-3930K Processor,ASUSTeK COMPUTER INC. SABERTOOTH X79
Tri fire R9 280xes, 580 sli, possibly tri sli though I doubt the ultra will run with the reference cards, or if they do ,not very well even with ocing.
I do have a big enough psu with enough pcie plugs so maybe I'll try it anyway....
FF
  #70 (permalink)
Old November 24, 2013, 08:11 AM
Absolutely submit even if there are higher ones, sometimes they get disqualified for a bad screenshot or something else and the next in line will be automatically used. Always good to have a backup.
Also, there isn't any reason to put all the stages on one screenshot but you still have to have the DETAILS tab open. You can see it on your score box one of the options below is the scores says "Details..." that box needs to be open so that your different stage scores can be seen.
Country Cup 2012 - Do your Country Proud! Rasparthe Overclocking, Tweaking and Benchmarking 145 January 4, 2013 03:16 PM
pes 2013 vs fifa soccer 2013 yehia7000 Gaming 0 October 6, 2012 06:48 AM
Your Country needs YOU! mkultra Overclocking, Tweaking and Benchmarking 87 January 21, 2011 01:09 PM
Sorry! This thread is not available in your country! automatic O/S's, Drivers & General Software 5 March 26, 2009 08:27 PM
Country Folk Technology enaberif Off Topic 1 February 3, 2009 12:40 PM
