Old October 8, 2013, 02:59 PM
trodas's Avatar
Smile MSI 6340 recap
Some five years ago my friend Peter give my this MSI 6340 micro ATX mobo with the Duron 750 CPU. It allegedly worked, but very, very unstable. However I got intersed, because I see mainboard back from 2001 for Socket 462 processors - Duron, Athlon - that got interestingly designed Vcore regulator and mainly a polymer Fujitsu caps. The yellow ones are polymers - regardless that they have the top perforations like elektrolyte caps:
Also as they say - everything small is nice. And this board is really small, almost like just fit tomy hand:
The fact that the mainboard is unstable is understandable. It is only enough to look, what caps are on it - many bad caps like these Chhsi ones:
And these terrible caps are combined with polymers, witch is trully interesting combination, witch in the end probably allow the board to survive all the time working. At least sort of...
Near Vcore output coil, witch get pretty how when the caps in Vcore are bad, the Chhsi cap is leaking now:
...but it looks like these two good polymers hold him pretty well, so the computer somehow worked.
Except quality polymers there are on the mainboard also good caps - Chemicon KZE - as input filter caps, witch sure worked well. Even I did not trust Chemicons much, the bad batches of them are only the KZG, KZJ, TMV and TMZ series, not the KZE. And on top of that, they are nicely green:
However all that is not going to stop the instability of chipset, witch power voltage is "filtered" Chhsi terrible cap...
But all it all this looks like a decent Vcore design (for 2001):
560uF 4V Fujitsu polymers and 2700uF 6.3V Chhsi terrible caps is almone relatively qualite Vcore filtering, unless they start to break down, of course:
For rams and USB ports voltage filtering are used these bad caps Tayeh:
Of course the big problem is, when you push to big and heated coil a capacitor. This cap is really having a troubles, when the whole cascade is start to overhat:
However as you can see, bad caps are bulging even when they are long away from all typically overheating componets, like coils and mosfets:
MSI 6340 v1
2x 4700uF 6.3V d12.5 (Chemi-con KZE) -> 2x 4700uF 6.3V Panny FM d12.5 - P12347-ND
4x 2700uF 6.3V d10 (Chhsi) -> 4x 3300uF 6.3V Samxon GC d10
2x 820uF 4V d10 (Fujitsu) -> 2x 2700uF 2.5V Samxon ULR d10
2x 560uF 4V d8 (Fujitsu) -> 3x 1000uF 4V Samxon ULR d8
6x 1000uF 6.3V d8 (Chhsi) -> 6x 1000uF 6.3V Samxon GC d8
3x 330uF 6.3V d6.3 (Tayeh) -> 3x 470uF 6.3V Samxon GD d6.3
2x 47uF 16V d5 SMD -> 2x 47uF 16V Panny FK SMD d5 (16V) - PCE3397CT-ND
4x 10uF 16V d4 SMD -> 4x 10uF 16V Panny X5R SMD ceramic (4V) - PCC216CT-ND
(one polymer I added near the CPU, because it was removed and these 47 and 10uF SMD little caps I did not yet replaced, as I did not have anything to replace them with ATM)
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old October 8, 2013, 03:12 PM
trodas's Avatar
Smile
So years ago I already gather for this recap the caps, witch give me Big Pope - at lest these Samxon caps. Adding the 1000uF 4V cap increased the total Vcore output capacity to 18 300mF in 8 caps! (for example the famous Socket 462 mobo DFI Lanparty B have Vcore output wth only 4 caps and 13 200mF totl capacity - and no polymers!)
Whole look at the Vcore part of the mainboard after recap:
Look at the bottom caps from Vcore and for the AGP powering:
Much smaller todays polymers (560uF was - 1000uF is) for the same voltage is really just small "bits" compared to these 3300uF Samxon GC caps near them:
On the other hand, a 2700uF Samxon URL polymers are quite big pieces of caps:
And at the end, whole look at the MSI 6340 mainboard - little mobo:
Fun fact - after powering the mobo for the first time it show up, that for whole five years the real time clock is running. And on top of that, it even show good time - only +30min, witch is for 5 years w/o usage and with desoldered caps something amazing, I did not expect that :) And mobo is working quite well after the recap, even that the new CPU-Z version does not detect FSB, witch is weird. But the CPU-Z autor is already asked for some info to fix this, so there is a hope that this get fixed:
CPU-Z Validator 3.1
FSB 0 is not looking really truthfully :D
Also is worth noting, that the mobo has a pretty detailed setup in the bios (especially considering that this is VIA KT133 chipset and SDRAMs) and even overclock possibilities, where one can choose from Default setting (100MHz) to 112MHz FSB (37MHz for PCI). However the result from this last settings (with so quality caps I did not expected and problem so I tried this right away) is, that CPU is working at 256MHz when using this setting :D (30x7.5) Well, there is a good deal of fun with this little MSI mobo... :)
Old October 12, 2013, 03:59 PM
trodas's Avatar
The underclocking bug shown up:
CPU-Z Validator 4.0
New CPU-Z beta does finally show the FSB:
(but the mobo does not know AXP cpu at all)
However at least HWbot use my picture for the MSI 6340 mobo:
MS-6340 @ HWBOT
...yet I desoldered the parallel and serial ports, so I have to paste them there from another photo... and also MSI 6340 was not produced with Samxon URL polymer caps. That are, in fact, produced about 8 years after the mainboard... :)
Old November 20, 2013, 07:35 PM
MARSTG's Avatar
Why do you even bother to resurrect such old busted technology?
Old November 21, 2013, 03:38 AM
trodas's Avatar
Because it is fun and interesting experiement, if I can make it working. It also helped find a bug in CPU-Z, make me realize that lack of CPU support in bios could mean, that AXP at 1100MHz could be SLOWER that just Athlon at 900MHz (with half the L2 cache, lol):
HWbot wPrime bug? Athlon faster that AXP! - hwbot.org
...and in genereal I hope that I can make the FSB 133MHz working, when the WR is 118MHz: Christian Ney`s Reference Clock score: 118.01 MHz with a MS-6340
All in all, it is IMHO better that just trash the thing away for being too obsolete (witch it is, no doubt about it). Now I can hope that someone help me to modify the bios and I get AXP running pretty well in this. Also, there is the 33MHz FSB bug, witch can be exploited to make 12h+ Prime HW bot runs (ATM the longest 32M run was 8h, but I change the multiplier on my Duron and try get to the 12h :D :) ).
Why not? What is the harm in doing so?
I replaced the remaining 4 SMD 10uF caps with a 22uF SMD ceramics ( JMK316AB7226MLHT ) and the two 47uF 16V SMD caps with 47uF 16V SMD Nichicon polymers ( PCG1C470MCL1GS ) ...
...and added the missing JP9 jumper! Soldered it right it... :D
Now what is JP9 jumper on MSI 6340 you might ask? Open = 100MHz, Closed = 133MHz says PCB. But in reality it mostly did not even post and when it do, then it is still 100MHz FSB ... Gotta try different rams and bios settings (relaxed) to higher FSB :) Old school fun!
MSI PM8M3-V recap trodas Overclocking, Tweaking and Benchmarking 2 October 2, 2013 06:20 AM
Completed Point of View 7300GT gfx card recap trodas Case Mods, Worklog & Gallery 3 August 30, 2013 12:34 AM
