Old September 23, 2013, 10:19 AM
trodas's Avatar
I must say that since I never had in my hands such modern board, I have absolutely no clue how different from Vcore is the "power to the cpu" voltage. Sounds quite the same for me. Some settings are pretty explainatory (like the L2 cache voltage), but at this I'm end up quessing that it should be some non-permanent Vcore voltage for power up... like 20mS of juice and then apply the standard 1.2V setting?
Dunno.
What is the default setting anyway? My BIOS does not allow me anything like this:
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old September 23, 2013, 11:36 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
With Haswell Intel integrated come of the VRM parts. So now you feed the integrated VRM a bunch of juice and it in turn feeds the CPU (each mfg calls the VRM part something different). Since both are separate you can (and usually do) have to boost the power to the VRM along with the 'vcore' setting for higher oc's. ;)
Its a whole new ballgame and its a big part of why the H's are running so damn hot.
Dunno.
if your opponent has a conscience, then follow Gandhi. But if you enemy has no conscience, like Hitler, then follow Bonhoeffer. - Dr. MLK jr
Old September 23, 2013, 12:29 PM
trodas's Avatar
Ah. That looks like two steps down VRM - that could be cool. Back in old times, the CPU VRM is feed from 5V, then 12V lines when 5V was not enought. Now one can regulate how much joice got the final step from the first one? That might allow optimizing the heat output (read - minimize the loses) once maximum stable overclock is reached, by just cutting down the voltage a bit, so the last step is not so huge...
Obviously Haswell CPU's are sweet for users and overclockers then. Especially when there is plenty of these interesting settings. Do anyone bother to describe them anywhere where users can look and understand these better?
With old-good AMD K7 times is was straightforward and easy to understand:
...but now are there too much settings to screw something up :)
Old September 23, 2013, 07:56 PM
Delavan's Avatar
Quoting Trodas:
Lol, you have fun bro, but all those settings are no sweet/fun to me! They are there to harass me...confuse me, stress me out, make me believe things and steal time of my life I'll never get back... lol..
Honestly, i'm touching wood here....4.5GHz is plenty and is what I was looking for...so PLEASE STAY STABLE FFS!
The "initial" CPU voltage, is the POST voltage. ASUS really screwed up the naming of things...they didn't use standardized vocabulary, compared to other MOBO manufacturers (at least for THIS gen).
Initial is voltage of the CPU at POST, and I guess it's on the MOBO's VRM side or things...as Haswell has CPU VRMs on-chip and deals with vCORE internally... I think it's called VRIN on other mobos, NOT SURE....
Eventual is the always-on voltage on the MOBO's side....I think it's called VCCIN on other mobos...
I might be confused....I just think ASUS was on Cr4ck for not using the same terms as the other MOBO manufacturers... this is a failzors IMHO...
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old October 3, 2013, 02:29 PM
SAS SAS is offline
hey - thanks for the input guys - but I am still very confused.
can I do it manualy from Ai suite 3? At the moment then I have a 4.4 GHZ and it says OC voltage at 1.25 v - and I was wondering if FROM ai suite3 if I could change that to manual and go down to 1.222 v for example? Could some one pls make some dummies screenshots of where I could go fully manual and see if I can bring down the voltages.
Would apreciate it a bunch!
[FS] ASUS Maximus VI Hero Eldonko Buy/Sell & Trade 3 August 30, 2013 06:24 PM
ASUS Z87 Maximus VI Hero Review Comment Thread SKYMTL CPU's and Motherboards 20 August 27, 2013 11:10 AM
Civilization V pdf Manual Available ipaine Gaming 21 September 21, 2010 09:49 AM
ASUS develops manual GPU overclcoking tool Babrbarossa Press Releases & Tech News 1 July 5, 2007 09:34 AM
