Old September 12, 2013, 08:51 PM
Default Sabertooth Z87 & i5 4670k 3.4GHz
Currently OC to 4.2Ghz, running Prime95. According to RealTemp 74c 72c 70c 65c. Vcore 1.2V
Old September 12, 2013, 09:29 PM
Birk's Avatar
Nice, is that on Stock cooler?
Old September 12, 2013, 10:21 PM
Air cooled, Hyper212EVO.
Old September 13, 2013, 12:13 AM
This Haswell chip runs hotter than my old 2500k on the same cooler.
Old September 13, 2013, 01:32 AM
IRQ Conflict's Avatar
Haswell has a reputation for running hotter than all the chips that came before it. It is due to the amount of stuff integrated into the chip. You might want to go with water cooling for your rig.
Old September 13, 2013, 12:39 PM
Guess I'll have to watercool if I want to push it higher. But for now it's running stable, I've lowered the vCore to 1.18v
Old October 6, 2013, 08:20 PM
r0k0's Avatar
mine idles alot lower then my 2500K but runs the same temps @ 3.8Ghz ( stock turbo boost ) instead of 5.0Ghz on the 2500K lol
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
4670K or 3570K? Dr_BenD_over CPU's and Motherboards 4 September 5, 2013 01:50 PM
Intel Haswell i7-4770K & i5-4670K Review Comment Thread SKYMTL CPU's and Motherboards 53 August 14, 2013 10:25 AM
i7 4ghz :D vagnaar Overclocking, Tweaking and Benchmarking 18 January 16, 2010 01:41 PM
P6T i7 920 3.4GHz??? sinticfury Overclocking, Tweaking and Benchmarking 3 August 20, 2009 07:57 PM
