Old September 12, 2013, 06:57 AM
Dead Things's Avatar
Originally Posted by sswilson View Post
some procs might actually put out better benchmarks with exactly the same settings.
^ this
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old September 12, 2013, 05:09 PM
That is a very interesting fact... It defies basic logic imo. I think if I do go forward with this I'll make a weekend trip to Edmonton/Calgary to hit up ME and save the shipping and tax and visit some family. The only issue is getting 4 or 5 in stock at once :)
Old September 12, 2013, 05:16 PM
sswilson's Avatar
Pure speculation but I could conceive of one area of a wafer having better point-to-point traces thus producing less loss in transmission. Don't most processes these days count heavily on the ability to error correct? If so, then perhaps a wafer which just happened to have near perfect connections on all areas might be able to perform calculations quicker because it doesn't have to do any error correction.
Like I said though... that's just pure speculation.
Old November 9, 2013, 10:02 PM
Well, I'm 99% certain I'll be going forward with buying 5 chips to over-clock them all. I am hoping to get my hands on a H220 closed loop to work on them with and Noctua NT-H1 paste. Since I'll be testing outside of a case, do you suggest I get a fan to blow air over the motherboard or anything like that? I don't exactly have a test bench or something of my own.
Old November 10, 2013, 01:53 AM
rjbarker's Avatar
To be quite honest I dont think you'll have to worry about NB, Mofset or Chipset Temps as you'll never reach uber crazy OC's high enough to warrant it......if you're concerned a 120mm Fan blowing over the Mosfet would be more than enough (but as said likely not required)......what exactly are you binning for?....one great chip?....
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 10, 2013, 05:05 AM
Bond007's Avatar
Since its really just a quick relatively crude test to find the CPU, I would probably just throw a small desk fan on the table pointing at everything on low just for the warm and fuzzy of keeping some airflow. That said, I am sure it would be perfectly fine without (or as mentioned above a single fan at the MOB).
Old November 10, 2013, 09:09 AM
More for the experience/challenge of playing with hardware and tweaking. I am obviously hoping the side effect will be that I find a CPU that's able to push 100-200 Mhz higher than the average or has better efficiency when over-clocked. After I finish playing with each chip, I won't be keeping the CPU at the max over-clock.
Okay, so I should be able to get away with being lazy about cooling the mobo parts then (at least while testing).
Thanks.
Old November 10, 2013, 10:00 AM
rjbarker's Avatar
^^^^ What Mobo will you be testing on?
MARK 11: 32.530
  #19 (permalink)
Old November 10, 2013, 10:46 AM
ASUS Rampage IV Gene mATX.
  #20 (permalink)
Old March 6, 2014, 08:45 AM
any results?
"Dell 5521" vs "Acer V3-571G" vs "V3-571G SSD" N7pSTR New Builds 3 May 7, 2013 04:03 PM
"BF3.3" Level 10 GT Case Mod is "Locked and Loaded" Mnpctech Cases 2 July 12, 2012 12:18 PM
Keyboard types "w " when i press "w" matthew2180 Troubleshooting 14 December 20, 2011 10:21 AM
How do i know if my "Drive Controller" is running in "AHCI mode"? Teo3201 Storage 2 October 8, 2011 09:54 PM
"Wii 2" Codenamed: "Project Cafe" BFighter Gaming 5 April 24, 2011 10:16 AM
