  #31 (permalink)
Old September 18, 2013, 01:49 PM
Dead Things's Avatar
I've also found that XTU needs a basically untouched OS. My slimmed Win7 that I usually use for benching was a no-go.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
  #32 (permalink)
Old September 18, 2013, 01:50 PM
Soullessone21's Avatar
My system when OCed is not BSODing but just turning right off as of late when clocked down runs great though :S hmmm
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
  #33 (permalink)
Old September 18, 2013, 02:16 PM
What specs? Not what's in your "My System Specs" right?
  #34 (permalink)
Old September 18, 2013, 06:52 PM
ipaine's Avatar
I'm going to try another drive with a newer cleaner install on it. I was trying to push this last night and I couldn't even get a run at 5GHz like I did before. Will see what I can do with that other drive.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
  #35 (permalink)
Old September 19, 2013, 03:58 AM
Thanks for the suggestions guys, but I did actually try all of those, using the Z87X-OC I first tried with F5b bios, then moved X02 and still same problem. Tried a stripped 32 bit Win 7, a full install of Win 7 x64 and full install of Win 8 x64. Haven't got around to ripping on it again but I'll try a totally different SSD, and a mechanical one to see if that is the issue.
  #36 (permalink)
Old September 19, 2013, 05:55 AM
DA RIG O! POWA!!!
MSI X79MA-GD45 got it for $50 at a super sale
3960X
16GB 4x4 2133 Gskill
240GB Neutron GTX
AX850 Corsair
GTX 770 Gaming MSI 2 and 4GB variants for testing
CPU cooled by the Intel AIO with new fans system games at around 55C max and Stability tests at 75 MAX!
Case is a open air lian Li Lian Li PC-T60B Advanced Test Bench - Black - FrozenCPU.com
When I run any OC through her she boots up and plays games fine but when I run a benchmark it shuts right off... and actually the power in that side of the house flickers haha
OS win 8 Pro 64
Site and Forum:
  #37 (permalink)
Old September 19, 2013, 10:02 AM
Symptoms kinda sound like the PSU may be on the fritz. Can you rule it out by subbing in a known-working unit?
  #38 (permalink)
Old September 19, 2013, 10:10 AM
... I gave it to Matthew for his donation my BNIB backup one and sold Hades my Seasonic.... right now I think the term I am looking for is SOL haha
Site and Forum:
  #39 (permalink)
Old September 22, 2013, 01:48 PM
Soullessone21`s XTU score: 1209 marks with a Core i7 3960X
first time the system Oced at all with out BlackSODing on me :S
Site and Forum:
  #40 (permalink)
Old September 26, 2013, 08:42 AM
Looks like my EVGA X79 config sucks just a little bit less than your MSI config, John - sorry! I did get it as high as 4.4 GHz with an older, more efficient BIOS version, but I stopped taking screenshots once I went into troubleshooting mode. I'll be borrowing a GA-X79-UD3 soon, which will hopefully help me figure out what's wrong.
Dead Things`s XTU score: 1282 marks with a Core i7 3930K
HWC Overclocking Challenge #4: Unigine Heaven, Red vs. Green Dead Things Overclocking, Tweaking and Benchmarking 26 August 30, 2013 05:21 AM
HWC Overclocking Challenge #3: wPrime UP+MP (Now with Prizes!) Dead Things Overclocking, Tweaking and Benchmarking 109 July 3, 2013 08:18 PM
HWC Overclocking Challenge #2: All-Out Ice Storm Dead Things Overclocking, Tweaking and Benchmarking 62 May 1, 2013 04:52 PM
HWC Overclocking Challenge #1: SuperPi 32M <4.0 Dead Things Overclocking, Tweaking and Benchmarking 79 March 31, 2013 09:43 PM
GIGABYTE and Futuremark Host P55 OverclocKing Challenge and 10K Challenge Gav Press Releases & Tech News 1 November 13, 2009 03:31 PM
