  #31 (permalink)
Old August 17, 2008, 08:42 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 14 - 540 points to level up
kk, heres something im not understanding, on the physics test, futuremark will allow a ppu to replace a cpu right?
your two gpus VS my 4
i just want to point out that I've got 4 gpus too, 2 x gx2 in that benchmark.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
  #32 (permalink)
Old August 17, 2008, 09:12 PM
Level: 12 - 372 points to level up
The ppu does not replace the cpu, it works along with it. Without the PPU, only 8 planes are in flight. With the PPU, 16 are in flight...so not only does it measure the addition of the PPU, it increases the workload so that they work in tandem.
So, we look at the single test in which you stomp on my score...a cpu test...how many planes do you see in flight?
Regardless, if we were to take just about any other type of test, like a game, I'd come out on top, if only from me having a quad @ 4ghz, vs your dualcore @ 3ghz...I mean, I could go and get two of the same cards you have, and the same board, and I'd be much faster...in everything except Vantage(because of the PPU, although I could choose which ran that specific Vantage test).
Don't get me wrong, your cards are faster than mine, but not with my cpu @ 4ghz, and not when your vgas are busy doing Phys-X.
Anway, try using a driver from before nV Phys-X, or turn PPU off in vnatage, and check the score again...
This is why Futuremark REALLY banned the scores....
Some peopel(alot) use Futuremark when considering buying a PC. A marketing tactic, for sure. Anyway, take the two benches we are looking at now, and if jsut considering this single bench, it would seem prudent to buy your rig over mine...but get 'em both home, and start playing games, doiong enconding, or whatever...the difference would be quite obvious.
That said though, crank up to 4ghz, and your system will beat mine in most games.
  #33 (permalink)
Old August 17, 2008, 09:39 PM
Ah ok, i wasnt aware that vantage upped the ante when including a ppu. shoots my argument all to hell ;D
I plan on doing alot of testing on that rig, unfortunatly almost imidiatly after getting that bench done i started having trouble (these two GPUs have trouble going from sli mode to single mode...) and had to waste a bunch of time sorting it out... then i got a call to go to work, so i wont be able to do anymore testing on that rig untill i get home in a couple weeks
so far i've got the cpu running at 4.2 on water, and the gpus oced to 750/1150 i didnt get time to do a bench like that though, wich i regret becuase i'm really curious as to what it can do.
  #34 (permalink)
Old August 17, 2008, 09:47 PM
ORB - World of Performance
This is my work computer, no phys X driver ;)
  #35 (permalink)
Old August 17, 2008, 09:54 PM
dead link.
  #36 (permalink)
Old August 17, 2008, 10:02 PM
fixed link
  #37 (permalink)
Old August 19, 2008, 06:25 AM
Dr_BenD_over's Avatar
Level up: 67% Level up: 67% Level up: 67%
Level: 10 - 93 points to level up
P13234
X6983
|Q6600 at 3.0|Diamond HD4870X2|G.SKILL PC2-6400-2x2048|P5Q Deluxe(0803)|1.866TB|XFiXM|245B|AL1916W|
Folding? If you're not doing it, you should ask about how to.
  #38 (permalink)
Old October 12, 2008, 04:30 PM
FrankyG's Avatar
Level up: 28% Level up: 28% Level up: 28%
Level: 9 - 170 points to level up
My Score...
Intel Q9550 @ 4.02GHZ
Evga 790i Ultra SLI
4GB Corsair XMS3 1600Mhz
2x Evga GTX280 SSC 1GB
Seagate 1TB HD
Antec 1000W PSU
Chieftec Dragon Case
Custom Watercooling Kit
  #39 (permalink)
Old October 12, 2008, 07:14 PM
Alwaysrun's Avatar
Level up: 27% Level up: 27% Level up: 27%
Level: 9 - 172 points to level up
I'm also highly suspect about this graphics benchmark legitimacy. I just ran the test on all stock settings and only scored 6753 points. My poor Radeon 4850 getting trounced by the 8800GT and single 9800 GTXs isn't really indicative of real world gaming power. Excuse me Vantage but I'm going back to playing Crysis Wars on 1680x1050 with all setting 1 notch from the top.
CoolerMaster CM 690 - Asus P5Q-E - Intel E8400 Wolfdale 3.0 GHz @3.85 1.26v - Corsair TX 750Watt - OCZ Vendetta 2 *Lapped - 2x2 GB Corsair Dominator PC2-8500
Palit Radeon HD 4850 @ 670/1023 - Seagate Barracuda 7200.11 640 GB - Maxtor 250GB - Samsung Lightscribe DVD+RW SH-223Q - 22" Samsung SyncMaster 2253BW
