Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old July 3, 2008, 05:15 PM
kruzn4evr's Avatar
Level up: 22% Level up: 22% Level up: 22%
Level: 11 - 264 points to level up
Just went quad, didn't think my score would improve by as much as it did, with one GX2 it was 11336, with adding the second one....ORB - Compare not too shabby, the big difference is in the gaming, Crysis plays sweeeeet!
evga 780i ftw - qx9650 w/GTZ - 4x1gb ocz plat.1066 w/cooler - 2x gtx 280's w/VID 428 Koolance fc wb's
wd vraptor 300gb - wd raptor 150gb - samsung sp 750gb - lg bluray dvd - TT TP 1200w - viperjohn nb
mips sb - Koolance drain valve and nozzles
mcp355 w/xspc top - xspc passive res - TT LCS Kandalf case
Old July 6, 2008, 05:56 PM
3.0charlie's Avatar
Level up: 47% Level up: 47% Level up: 47%
Level: 22 - 713 points to level up
Here's mine, with a single 4870.
Asus P5E Deluxe X48 (flashed to Rampage Formula) - E8400 @ 4.2GHz - Corsair HX1000W - Raptor 74Gb - Mushkin XP2-8000 2x2Gb - BFG GTX280 - Wc'ing: PA120.2 w/Panaflos, Stinger V8 - Lian-Li PC-V1000
Gigabyte GA-EP45-DS3L - Q6600 @ 3.0GHz - Corsair HX620W - Raptor 37Gb - Mushkin EM2-6400 2x1Gb - BFG GTX280 - IFX-14 - Antec Sonata II
Old July 7, 2008, 09:44 AM
Level up: 39% Level up: 39% Level up: 39%
Level: 12 - 249 points to level up
Some QX9650 @ 4170mhz, CrossfireX 3870x2 @ 950/1100, and Phys-X:
P17051
ORB - Compare
Old July 7, 2008, 09:55 AM
3.0charlie's Avatar
How on Earth did you manage to hit that high? I can't believe that a 3870X2 will almost double the Points over a 4870....
Old July 7, 2008, 09:56 AM
That's 2 of 'em. Hence the CrossfireX...Singlecard is Crossfire, at least to my addled brain! ;)
Single card I get a wee bit over 9.5k...8.8k GPU score. Clocking VGAs to 950 makes for a huge jump in score...without vga clocking I get a tad under 16k total score.
Old July 7, 2008, 10:35 AM
3.0charlie's Avatar
Thank you. Makes more sense... didn't see the X. So a single 3870X2 barely edges the 4870.
Old July 7, 2008, 12:51 PM
Barely, and in most apps the 4870 will be faster, due to the nature of the 3870x2. Remember that mine is "highly" overclocked too...
My rig is screaming for a couple Black Edition Radeon HD4870x2's...
Old July 8, 2008, 04:29 AM
kruzn4evr's Avatar
Very nice scores!....Can I ask what settings your using to hit 4.170GHz? I haven't really pushed my QX or the GX2's but I would like to give it a shot, I'm one of those who's just not very comfortable bumping the voltages, I've run at 4.1 but couldn't seem to get it 100% stable. I haven't oc'd the GX2's much yet either but I plan on it
  #19 (permalink)
Old July 8, 2008, 07:11 AM
I started a thread, feel free to pop in and ask away!
caDAVEca's Overclocking adventures.
  #20 (permalink)
Old July 28, 2008, 10:40 PM
Level up: 92% Level up: 92% Level up: 92%
Level: 8 - 16 points to level up
ORB - World of Performance
crap score
Forum Jump
Search this Thread:
Advanced Search
