Old August 24, 2013, 02:47 PM
Warcrimes's Avatar
Thanks for the advice, ill stick to cpu for now. ive droped my multiplier to 45 and lowered to voltages to a fixed 1.34 LLC 1. im happy with 4.5 and will try to push down the voltages max temp on prime was 67c
Old August 24, 2013, 03:55 PM
rjbarker's Avatar
Another I used to do (when I first started OC'ing a number of yrs ago), is run marathon sessions of P95....I no longer believe in this methodology as "I dont play Prime...I game"...with that being said, I now look for 15 - 20 passes of LinX.....if I get thru that...then I use my PC "as per normal, including gaming".....
I used to run LinX...get thru 15 passes...then run a marathon 10 hr session of Prime Blended and Prime Small FFT's...sometimes LinX would pass then Prime Belnd would fail after 7 hrs...found it frustrating.
Anyhow, another Forum member suggested 15 - 20 passes LinX (not that time consuming), then simply game and do whatever else you do...if no BSOD's...your good to go :) This may result in a "fail" running Prime, but who cares, you dont play Prime !!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old August 24, 2013, 06:31 PM
Warcrimes's Avatar
well ive been testing some more and i am now down to 1.325 fixed with LLC 1 at 4.5Ghz i played some games and no issues. im wondering if anyone can tell me the lowest someone went with a 2600k at 4.5Ghz lowest voltage.
Thankyou everyone for the help
Old August 24, 2013, 09:54 PM
"2.1 2.2 is meant for ivys good luck on a oem bios" What version of BIOS are you running? Also, if you can, try to get it stable at LLC 2 instead of 1 as most people who overclock "feel" that LLC 1 is not healthy for long term use.
Old August 25, 2013, 10:02 AM
Warcrimes's Avatar
currently using 2.1 i read around some people dont have problems others do. but according to asrock it shouldn't be a problem. I'll try LLC 2 from what i gather LLC 1 doesnt let the voltage drop so u constantly have more power more of the time, i currently have 4.5 Ghz stable at 1.325v do u think llc 1 with those voltages would still be a problem? im still trying to get lower voltages , just dunno what the lowest i can go
Old August 25, 2013, 01:36 PM
Problem with LLC 1 is that a bit of vdroop is actually important to protect your chip's long term health. LLC 1 you don't ever get that benefit of having a touch of vdroop, which is good for over-clocking, but not for self preservation. I'm not saying a person can't run LLC 1 all day, but most people aren't willing to risk it for a long term setting. Yeah, too bad if your problems are due to installing the 2.1 BIOS :/
Old August 25, 2013, 06:48 PM
Warcrimes's Avatar
so far can't get anything stable unless on LLC1 and the preset OC by the mobo. which voltages for my taste are too high 1.408 max voltage for a 4.4Ghz oc. at 4.2 is stable and it's stock everything just multiplier changed multiplier to 42. it could be the bios update i skimmed through articles with the same issue. ill read through and get back soon
Old August 25, 2013, 07:04 PM
if you can downgrade from 2.1 I would.
  #19 (permalink)
Old August 25, 2013, 11:29 PM
Warcrimes's Avatar
i will probably have to contact asrock for this will get back with news. Will there be a significant difference between 4.2 ghz and 4.5 ghz. or not really?
  #20 (permalink)
Old August 26, 2013, 12:49 PM
Warcrimes's Avatar
it's a $15 charge for an older bios which i think is BS. im at 4.2 GHZ with stock setting and i feel its good enough if i see in the future that more overclock is needed i will pay it but i dont know if a .3 ghz upgrade is worth it. i really dont want more than 4.5 Ghz. has anyone felt a big impact from going up .3 Ghz?
Verizon Jumps the Border, Offers $700 Million for Wind Mobile SKYMTL Press Releases & Tech News 27 July 5, 2013 09:01 AM
XFX Jumps Off GTX 480 / GTX 470 Ship SKYMTL Press Releases & Tech News 60 January 30, 2011 03:46 PM
Vcore greyed out ... DRZDuke CPU's and Motherboards 1 July 5, 2010 12:07 PM
Phenom II X2 550 -X4 Vcore max mattlef CPU's and Motherboards 3 August 29, 2009 05:20 PM
vcore fluctuations and oc magictorch Overclocking, Tweaking and Benchmarking 11 July 5, 2007 01:40 PM
