Old August 5, 2013, 09:17 AM
Shadowmeph's Avatar
Default game latency fixers do they still work? wha tis your take on them
I remember way back when I first started to online gaming I used to a simple program that seemed to cut back on my latency sometimes a allot but I am wonder now if there are still programs or scripts that can do the same thing.
I am kind of doubting that they still work unless you are directly connected to a modem or have the script running inside your hardware fire wall .
this is a batch script that an acquaintance made that apparently works for her works but I am not sure if it would if I am going though a modem
what is your take on this or other such scripts or programs .
Oh I am not sure if this is actually aloud is this isn't allowed then please remove the script code and I apologize
Code:
@echo off
reg query "HKU\S-1-5-19" >NUL
IF %ERRORLEVEL% NEQ 0 CLS & echo RUN AS ADMINISTRATOR && pause && EXIT
setlocal enableextensions enabledelayedexpansion
SET /A i=0
SET FILE=Improve_your_Lag_Disable_the_Nagle_Algorithm.reg
FOR /F "usebackq tokens=1*" %%A IN (`REG QUERY HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces /se #`) DO (
	SET /A i=!i!+1
	SET REGKEY!i!=%%A
	echo.Windows Registry Editor Version 5.00>"%~dp0\%FILE%"
for /l %%A IN (1,1,%i%) DO (
	echo.>>"%~dp0\!FILE!"
	echo.[!REGKEY%%A!]>>"%~dp0\!FILE!"
	echo."TcpAckFrequency"=dword:00000001>>"%~dp0\!FILE!"
REG IMPORT "%~dp0\!FILE!"
Old August 5, 2013, 10:23 AM
Scripts typically don't do anything with modern games, most of the major developers already optimize network traffic as well as software implementations can. You would see a noticeable improvement if there was something wrong on your end. Sometimes with some of the older programs you might experience slowdowns because of how they work. (they simply "spam" packet requests to reduce latency)
Latency fixing services can work, as they typically offer you a direct proxy/VPN to their servers which are located in close proximity to popular game servers. But sometimes you're close enough to a server that it makes little to no difference. Not to mention they're typically on a freemium model.
Old August 5, 2013, 10:38 AM
Shadowmeph's Avatar
that makes sense to me, I remember bacak when playing ET my pind was very rarely lower then 95 which might not seem to high to some but when you are playing in tournaments it is huge. that was 6 years ago maybe even longer the funny thing is even now my ping averages in the high 90s lol
Free cas latency 9 ram? stolendo RAM 4 June 20, 2013 03:29 PM
High latency on wow? bf1 Gaming 5 January 26, 2011 02:36 PM
PCI latency Timer Kyure Troubleshooting 3 November 7, 2009 03:43 AM
Is this a good build to increase game performance? Work your magic! mtrpcic New Builds 8 October 4, 2009 12:09 PM
Getting a game to work with Vista? TwystedMonkey Off Topic 21 June 1, 2008 12:28 PM
