Old July 29, 2013, 06:22 AM
Varroa's Avatar
Default Overclocking/unlocking 6950
Hey Guys, recently I noticed my that my card was struggling with Tombraider on ultimate settings (1920x1200) so I decided to unlock the extra shaders and try some overclocking. The unlocking went fine (did not flash a 6970 bios but instead used my original bios and unlocked just the extra shaders). I haven't overclocked an AMD card in a little while so I was surprised to see they no longer have the "autotune" function and instead have 4 sliders (GPU/Mem/Fan/Power). So, I bumped up the GPU to max (840) and the memory half way (1275ish) and added 5% more to the power and it seems all stable (temps are fine as well). Is there anything else I should be doing? The max GPU speed wasn't very high so should I jump over to a different program to overclock? Suggestions? Also, I use to have this card underwater and now it is using the stock blower style fan so can somebody suggest a good aftermarket HSF for me? Thanks
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old July 29, 2013, 02:05 PM
You "overclocked" to 840 and 1275? That seems low, is it a reference card? My stock clocks are 880 and 1300, but I have a toxic edition.
Pick up a free copy of msi afterburner if you want to be able to overclock to dangerous levels.
The 6950 runs very hot overclocked so I would look for a dual fan solution. My 6k rpm fans are really loud vs the dual fan asus 6950 (I own four 6950s).
Old July 30, 2013, 05:34 AM
Varroa's Avatar
Yes, it is a stock/reference version. 840 is my max the CCC will let me go on the slider. I was looking at MSI AB and I will give that a try but I am worried about temps. Under water this card was great but now that it is back on air I am noticing the GPU/Mem getting pretty hot (but surprising the VRMs aren't).
Old August 26, 2013, 03:08 PM
Varroa's Avatar
Weid, MSI afterburner only lets me go to 840 mhz GPU as well. Am I missing something?
Old August 27, 2013, 05:35 AM
Varroa's Avatar
Looks like I need to do some reg tweaking to eliminate the 840 mhz wall.
Old August 28, 2013, 12:04 PM
Varroa's Avatar
Ok, I got the clock speeds unlocked but it is voltage locked still. I can't even get it to clock to 880 without the graphics driver giving me a "stop responding" crash. I ran it at 850 without any problems and temps were ok so any ideas on how to unlock the voltage?
Nevermind, I figured it out, now I get to play with voltages.
Old January 4, 2014, 07:04 AM
Trial Member
Default Y510p tweakin'...
Hi,
Can you tell me how to do this to my Y510p?
Chad
MSI Overclocking/warranty questions 6950 jordan6359 Overclocking, Tweaking and Benchmarking 3 April 11, 2012 09:56 PM
Unlocking 6950 toxic Masteroderus Overclocking, Tweaking and Benchmarking 0 March 3, 2012 01:58 PM
6950 unlocking help Matthecat Video Cards 3 September 9, 2011 01:12 PM
Unlocking 2 HD 6950's + Overclocking, is it possible? Zak_M Video Cards 6 August 30, 2011 05:25 AM
Sapphire Launches Radeon HD 6950 TOXIC Edition, Fastest HD 6950 Yet Sam_Reynolds Press Releases & Tech News 2 August 5, 2011 02:25 PM
