Old July 4, 2013, 06:44 AM
Dead Things's Avatar
Default HWC Overclocking Challenge #4: Unigine Heaven, Red vs. Green
Contest closed! Thanks for participating!
Welcome one and all to the (Not Officially) Official Hardware Canucks Overclocking Team! If you are new to the team, and want to learn more about what it is all, um, about, please see the introductory team thread here. How many times can I say about? About this many, I guess.
Introduction
This is the second of our two-stage competitions this summer, as we shift focus away from overclocking our CPUs and onto overclocking our GPUs! Like with the wPrime challenge, contestants will have two months to prepare scores in one or both categories. This time around, the challenge is to post the best score using the Xtreme preset for Unigine Heaven:
1. Any single AMD or ATI video card (Crossfire not allowed)
2. Any single Nvidia video card (SLI not allowed)
Play the fanboi and fight to pwn the other Team. Or play both sides against each other and enter both stages of the competition. The choice is yours. But when the dust settles, we will know whether Team Red or Team Green dominates the Pearly Gates!
Contest Guidelines
Use the HWBOT Heaven launcher to start the benchmark. Run the Xtreme preset for DX11.When you have your score, take a screen shot that includes:
  • Unigine Heaven main window
  • Unigine Heaven score
  • CPU-Z CPU tab
  • CPU-Z Memory tab
  • GPU-Z Graphics card tab
To enter this contest, you will need the following:
Background image to be used in all submissions (use download link for 1920x1080 or attachment below for 1024x576). Without this background image in your verification screenshot, your contest entry will be invalid.
Unigine Heaven benchmark - This is the HWBOT launcher that you must use for this competition. Alternate versions of the launcher include light and typical.
CPU-Z Ė At minimum, open two instances and show the CPU and Memory tabs in your verification screenshot. Those using an IGP to submit a score for this challenge must also open a third instance to show the Mainboard tab.
GPU-Z -
Just the main Graphics Card tab is needed. If GPU-Z reports your video card incorrectly, a different reporting program may also be used.
Contest entries will be accepted from 12:01 AM EDT on July 1, 2013 until 11:59 PM EDT on August 31, 2013. The official time stamp for a contest entry is based on when the submission link is posted in this thread.
How to Participate
Once you have your best Unigine Heaven score, submit it using hwbot.org here. Make sure your submission is in compliance with both the specific Hardware Canucks contest rules and the general hwbot.org rules for Unigine Heaven Xtreme Preset. After you have submitted your score to hwbot.org, post the link to your submission in this thread to enter. Good luck, and may the best overclocker win!
Awards
In this contest, participants are competing for points towards the Championship Cup Series. Points will be distributed to contest participants as follows in each stage:
1st place = 10 points
2nd place = 7 points
3rd place = 5 points
4th place = 3 points
5th place = 2 points
All others who submit a score but donít reach the top five will receive one point towards the Championship Cup Series.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
HWC OC Challenge #4 Standings
Nvidia
1: G777 @ 3530.77 ~ 10 Points
2: JayDeeHobbit @ 2026.25 ~ 7 Points
3: Dead Things @ 1841.57 ~ 5 Points
4: 4DoorGTZ @ 1805.44 ~ 3 Points
5: ipaine @ 1672.5 ~ 2 Points
AMD
1:
Dead Things @ 919.4 ~ 10 Points
Old July 5, 2013, 07:33 PM
ipaine's Avatar
Anyone have issues running that? Whenever I try running it I just get a black screen with a unigine logo in the corner and fps in the 8000 range. If I hit esc I get the menu that comes up but the actual benchmark doesn't work. I have even tried it making sure SLI was disabled and I also disabled my second monitor and still the same thing. Any ideas?
Unigine 4.0 works fine and so does 2.1 if run without the HWBOT launcher. Any ideas?
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old July 7, 2013, 07:24 AM
G777's Avatar
OK, I'll go first...
Gav777`s Unigine Heaven - Xtreme Preset score: 3594.29 DX11 Marks with a GeForce GTX Titan
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old July 7, 2013, 07:39 AM
KaptCrunch's Avatar
note that PhysX/Ageia will kick in and a give a different score when 2 cards used on bench test
Old July 8, 2013, 11:46 AM
Not to worry, oh Kapt my Kapt - there's no PhysX in Heaven, even if you try to enable it. So if you have a multi-GPU setup, you only need to disable xfire/sli to run the benchmark - no need to physically remove any cards (unless you're hardcore like Gav).
Talking about which...
...Wrong HWBOT link it looks like, no?
All I know is that it's a fairly common issue that others have run into as well. It seems the wrapper causes a freeze when certain dll's are missing from a modified or stripped OS. I don't know if there's a fix so unless your google fu can produce an answer, my only suggestions might be to try reinstalling .NET 4.0 or DirectX...
Old July 13, 2013, 11:49 PM
fishingfanatic's Avatar
Smile Oveclocking Tweaking and Benchmarking
Here's a cpl of results from the quad sli.
FF
Old July 14, 2013, 06:08 AM
G777's Avatar
Whoops
Gav777`s Unigine Heaven - Xtreme Preset score: 3530.77 DX11 Marks with a GeForce GTX Titan
Team Thread
Old July 14, 2013, 07:42 AM
Fantastic score!!!
I'm going to have to start asking for help to learn how to oc ram, gpu, and cpu together so I might get close to that score 1 day...
FF
Old July 29, 2013, 05:19 AM
Slaughter's Avatar
I've never played with Unigine before. First run wasn't so good. Going to give it another go tonight and hope to break 1000 points. :P
Looks like 1247 is the WR on the bot for this card... Unfortunately won't stand up against the Titan. :P LoL.
Going to need a 7970 to try and compete against that. :S
HWC Overclocking Challenge #2: All-Out Ice Storm Dead Things Overclocking, Tweaking and Benchmarking 62 May 1, 2013 04:52 PM
HWC Overclocking Challenge #1: SuperPi 32M <4.0 Dead Things Overclocking, Tweaking and Benchmarking 79 March 31, 2013 09:43 PM
Unigine Heaven 2.0 Benches rjbarker Overclocking, Tweaking and Benchmarking 8 April 13, 2010 08:33 AM
Unigine Heaven 2, Tesselation, and directx 11 MarkOne Gaming 17 March 24, 2010 04:23 PM
GIGABYTE and Futuremark Host P55 OverclocKing Challenge and 10K Challenge Gav Press Releases & Tech News 1 November 13, 2009 03:31 PM
