Old June 23, 2013, 11:18 AM
Caldezar's Avatar
Default Problems OC'ing i7 920 D0
So a friend of mine is staying with me for a while and has brought his PC with him. He's asked me to give him a hand OC'ing his D0 920. I figured that it should be a breeze given all the hype around this chip. However, I'm running in to a lot of problems with it. I can't even get the chip to boot at 3.66, and even a relatively modest OC to 3.5, jacking the vCORE all the way up to 1.5 (which I would not do permanently by any means) results in constant core failures in Prime95. (Half the cores stop after a few seconds, while the rest carry on running.) Running Prime95 on stock is completely stable though, so I don't think it's faulty cores.
My experience with the 1366 series is extremely limited, and this is getting under my skin. I know it could just be a bad chip or board, but maybe someone has suggestions?
Gigabyte x58a-ud5
Hyper 212 EVO (Stock clock = 65c under load. Seems high to me for stock?)
Core i7 920 D0
12GB Corsair XM3 1333 1.5v
Cooler Master 650W PSU
Case is well cooled. 3x120mm and 1x140mm (plus the CPU cooler) cycling air quite well.
I've played with several configurations in the BIOS for OC, but mostly I've been leaving the multi at 20 and adjusting the base clock up. Then I jacked the vCORE until I could get it to boot. Oddly though, even the slightest of OC's requires huge increases in vCORE just to boot in to Windows.
*EDIT* - Before anyone asks; yes I keep the RAM clocks at or under rated speeds.
Need some experienced advice here please. Understand I'm not at all new to OC'ing, but this chipset is a new area for me.
Old June 23, 2013, 11:32 AM
sswilson's Avatar
Did you try it in dual channel as opposed to tri? I'm really thinking it's the memory......
edit: I'm also thinking that an OC'd / overvolted 1366 system might be a bit much for a PSU that's probably only good for around 500W clean power at best.
Old June 23, 2013, 12:01 PM
Caldezar's Avatar
I've never converted a triple channel system to dual. Is it as simple as running 2 sticks? Or do I need to change something in the BIOS? On a side note, mem tests come up clean.
I considered this power issue, but it's also only running a single 6850 as a GPU. Although it does have an SSD and 2 HDD's.
Old June 23, 2013, 12:56 PM
For successful overclocking there are many problems you can run into:
1) Can your components handle it? (motherboard, PSU, memory, etc). The UD5 is an excellent overclocking board if yours is working properly. the D0 chip should overclock quite well if it hasn't sustained any damage from previous voltage increases (if any). Is your memory happy to run at 1.65v for overclocking? I bought a single rail beefy PSU so I don't have to think about rails, etc.
2) How much voltage/ratio tweaking do you need to do for the graphics card (i.e. IOH core) and memory to be stable?
3) Too much vcore can make an overclock not work. QPI/VTT voltage is very important too.
4) certain power saving settings or special CPU functions and interfere with an overclock.
WAAAAY back when I was doing regular overclocking and tweaking with my board (now it's stable, so no need to push it) I was trying to keep my progress updated: Starting the i7-930 GA-X58A-UD5 o/c - Rampant Speculation Forums
Have a read. It will be a start.
Old June 23, 2013, 01:01 PM
sswilson's Avatar
Yes, shouldn't be anything required in bios.
Old June 23, 2013, 03:52 PM
Your_friendly_gamer's Avatar
Try these:
V core: 1.275
DRAM V: 1.66
QPI: 1.3375
PLL: 1.88
Old June 23, 2013, 03:56 PM
BLCK 200
changed the memory voltage to 1.66 or 1.67
QPI Clock Ratio 36
Uncore Clock Ratio 18
LLC i put it on regular to meet intel standard whatever
CPU V core to 1.3375
QPI/VTT Voltage 1.275
CPU PLL to 1.88
Old June 24, 2013, 08:36 AM
Caldezar's Avatar
Thanks everyone for chiming in on this. I was wracking my brain for quite a while, and then I decided to physically inspect the chip. This is what led me to discover that one screw on the heatsink was extremely loose and there was very bad contact. I ALSO discovered that he didn't use enough thermal paste. This was an obvious red flag to me, however I am curious how the temps didn't soar over 100 in our attempts? I can only assume that the cores that were shutting down immediately were doing so because of the heat and didn't get a chance to register?
Regardless, I took the heatsink off, cleaned everything, reapplied paste and reinstalled the heatsink. Now I've got the system running 3.8 stable with no issues so far, and I'm thinking that may be where we decide to leave it since this processor has taken enough heat abuse in it's life.
Thanks again for all the help.
Old June 24, 2013, 08:40 AM
sf101's Avatar
You need to match certain settings on 1366 when overclocking
I'd change my dram bus voltage to 1.55 or what ever is closest up to 1.65 if needed.
You will be overclocking with bclk
Voltage of no higher than 1.35 should be necessary to even hit 4.0ghz typically and thus going past that for clocks as low as 3.5 means something else is wrong here. it can even cause heat fails on the cpu earlier with more voltage after a point i would back my voltage down to 1.3 for now and work from there until it gives 101 error in prime.
For pll try anywhere from 1.8 to 1.96v stability may vary.
Depending on bios your qpi/deram voltage or uncore/memory controller voltage is usually good at 1.35v - the big thing here is keeping it at least 0.5v difference from your dram voltage.
other than that only thing else i can think of off the top of my head is uncore frequency make sure its double your ram frequency.
cant think of anything else that was important but its been a little bit since i oc'd mine.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Pc on tv problems. kyle_L Troubleshooting 3 December 4, 2010 08:37 PM
mic problems Samael Audio 12 March 18, 2009 12:44 AM
Help Please (2 problems) AnthraxAdrian Troubleshooting 20 April 27, 2008 11:34 AM
having problems slisgrinder Overclocking, Tweaking and Benchmarking 2 April 14, 2008 06:47 PM
Big Problems Feff Troubleshooting 9 January 23, 2008 04:24 PM
