  #31 (permalink)
Old May 31, 2013, 10:32 PM
rjbarker's Avatar
All good here Slik PCI-E 3.0....although I did read thru that Thread awhile ago. Not much of a difference at all between PCI-E 3.0 vs 2.0, especially if your not into running Benchmarks for those peak scores.
Did you try running the nvidia Patch again to see if that will fix it?
Firestrike Extreme: 21.452
MARK 11: 32.530
  #32 (permalink)
Old June 1, 2013, 03:53 AM
Slik's Avatar
I'm going to leave it at PCIE 2 stock settings foor now. I intend to get IB-E and that should have a proper PCI-E 3.0. That is if it's compatible with my RIVE.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
  #33 (permalink)
Old June 1, 2013, 11:06 AM
rjbarker's Avatar
I see.....yes IB-E will be compatible as in same Socket and Chipset (4930K / 4960X), its the Haswell - E (next year) that will not be compatible...although same socket, new Chipset, native support for PCI-E 3.0 and SATA / USB 3.0...no 3rd parties.
MARK 11: 32.530
RIVE - Only 12GB with 16GB installed ? rjbarker Troubleshooting 50 June 4, 2013 08:43 AM
Completed Procyon II -Reborn w RIVE, 3930K & 16GB Corsair Dominator 1866 rjbarker Case Mods, Worklog & Gallery 10 May 17, 2013 04:42 PM
Asus RIVE and W7 UEFI Install rjbarker O/S's, Drivers & General Software 9 May 6, 2013 08:37 PM
Koolance block now avail for RIVE X79 Eldonko Water Cooling 1 November 30, 2011 04:15 PM
initial settings Jim CPU's and Motherboards 3 July 23, 2007 02:17 PM
