Old April 3, 2013, 04:38 AM
Skyllz's Avatar
Default Scratching my head here... OCing i5-750 again...
So I replaced my P7P55D-LX that was giving me trouble with a EVGA P55 FTW(Thanks 10e). No more USB issues, boots properly everytime, all is well when running stock.
I had a stable OC of 3.4 on there(Speedstep/turbo/c-state disabled), I had even pushed it to 4.0 at some point but did not like the temps so I scaled it down. It had been running like that for 1+ year.
Now I cant load windows with anything other than default setup(fresh CMOS wipe, default RAM and CPU). I get BSOD about 5 seconds in everytime. I used the same values I had on my previous mobo, raised the voltage a little, re-entered RAM data, etc...
Tonight I will be re-seating the CPU/ram/power connectors, just in case...
Something special I need to know about those P55 FTW? I have been going over OC guides and I cant see waht I could have done wrong.
Is smoke supposed to come out of there?
Old April 3, 2013, 01:19 PM
Skyllz's Avatar
Problem fixed...
Reset CMOS, load optimized default, set RAM manually, do not use XMP Profile, set BLCK 170:20 and off I was to 3.4 again, been running Prime95 for 30 minutes and no hicups. Not a "real" test per say but unless I run into issues I will just leave it at that and enjoy it.
Old April 3, 2013, 02:56 PM
Skyllz's Avatar
Just an update again, trying to pass time browsing while Prime95 is running...
Now at 3.6, been Prime95ing for over an hour, temps at 63-65c on all cores with a Zalmann CNPS10X Performa with Zalmann thermal paste I had left-over.
Quite happy with this upgrade, it will make my old rig last an extra 1-2 years hopefully before I upgrade again. I cant see myself being CPU limited anytime soon now.
Now if I could put my hands on another GTX560 it would be awesome.
HP laptop dvd burner scratching DL DVDs sankukai Storage 3 September 22, 2011 09:59 PM
Patriot Box Office vs. Asus O!Play: Head 2 Head Cheator Member Reviews 43 August 30, 2010 07:43 AM
This is a head scratcher. Dr_BenD_over Troubleshooting 5 February 5, 2010 08:21 AM
Painting my case: how do I stop paint from scratching off? quikgp Guides & How-to's 62 October 15, 2009 05:24 PM
Scratching the Starcraft itch CMetaphor Gaming 9 August 24, 2009 12:57 PM
