  #31 (permalink)
Old April 5, 2013, 07:35 AM
Dead Things's Avatar
Yeah, we had a pretty good idea coming in that Ice didn't scale much with SLI or Xfire, which is why we didn't put any restrictions on the number of GPUs allowed for the contest.
Despite what Janus says about the test being CPU-bound, Gav's testing yielded basically the same physics scores with 12 threads on a 3960X and with 4 threads on a 2500K.
So what I think Janus meant to say is that Ice was not meant to illustrate the full potential of high-end hardware. But that is not to say the test does not scale with higher-end GPUs, as Gav's Titan score clearly illustrates.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
  #32 (permalink)
Old April 5, 2013, 11:14 AM
Rollergold's Avatar
Any reason why my GTX 680's would be crushed by a single GTX 580, something doesn't add up here >_>
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
  #33 (permalink)
Old April 5, 2013, 12:01 PM
G777's Avatar
If you mean ipaine's score, that's 2XGTX 580 he's running I believe.
He's also rockin' a 2600k @ 5Ghz vs your 920@4Ghz, faster memory on a newer architecture and some good clocks on those cards.
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
  #34 (permalink)
Old April 5, 2013, 01:00 PM
JayDeeHobbit's Avatar
There is a bug in Fire that has to do with a microsoft update file.
I deleted the file and my Fire score went to over 10,000.
You might have the same bug. File name to delete is: KB2670838
This bug has to do with the "Fire" test though and I doubt it will impact the score in "Ice" at all.
(Edit: Warning though as this is a MS update and the impact is unknown to me. I have lost my upgrade to Explorer v10 and went back to v9 and I believe removing this update is the reason.)
As for your scores on "Ice" I posted a question about my low scores on the Futuremark forums. It seems that in high end multi-gpu setups we max out the Ice benchmark and it becomes heavily dependant on your CPU clocks for the final score. I don't understand the technical aspect of it but here is a link to my question and the answer on Futuremark.
680 sli low score 3DMark - Page 3
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
  #35 (permalink)
Old April 5, 2013, 01:10 PM
I'm not a hardcore OCer at all so it's all "shrug shoulders" to me when technical stuff comes into the picture. I would think that SLI 670's or 680's would outperform a single Titan but I dunno.
But G777 certainly does have BIG OC numbers on both CPU and GPU =
Edit: Doah! I posted Gav above = don't know why = it's G777 with Titan goodness.
  #36 (permalink)
Old April 5, 2013, 01:39 PM
Yeah - but remember with Ice Storm, you're only getting about a 10% premium with SLI, if that. For all intents and purposes, it is essentially a single-card benchmark.
  #37 (permalink)
Old April 6, 2013, 03:07 PM
Well instead of doing yard work *cough* I decided to try to bump my Ice score today.
I bumped my GPU OC a little (there wasn't much room to play from my previous OC) but the results were... meh...
I hadn't really played with my CPU OC for the Ice as I thought this would be more of a GPU test. So I played with my CPU OC and on my initial OC increase I've went from 4.6ghz to 4.8ghz and it kicked Ice in the behind!
Sitting at 210k on Ice now NVIDIA GeForce GTX 670 video card benchmark result - Intel Core i7-3770K Processor,ASUSTeK COMPUTER INC. SABERTOOTH Z77
Didn't submit the score as I hope to get to 5.0ghz OC before I submit.
So a heads up to those who want to get their OC groove on for the Ice challenge = GPU will only take you so far but if you hit the CPU as well some OC goodness awaits!
  #38 (permalink)
Old April 6, 2013, 03:52 PM
G777's Avatar
Very nice JD
Don't make me go buy another Titan
Team Thread
  #39 (permalink)
Old April 6, 2013, 03:58 PM
Soullessone21's Avatar
Originally Posted by G777 View Post
Very nice JD
You got a email home slice and when my wife gives me time to OC I will get some better numbers for my 660 OC TF pathetic setup haha
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
  #40 (permalink)
Old April 6, 2013, 06:17 PM
ipaine's Avatar
Damn you!!!! I was so close to you and now have no chance of catching you. Man that is one unpleasant side effect of all this benching, I need to upgrade my dual 580's!! Dammit if it wasn't for the new monitor I could have gotten at least one 680.
What driver are you using may I ask?
"Nothing sucks more than that moment during an argument when you realize you're wrong."
https://www.evga.com/associates/defa...CUV5OY6FY0U02O
HWC Overclocking Challenge #1: SuperPi 32M <4.0 Dead Things Overclocking, Tweaking and Benchmarking 79 March 31, 2013 09:43 PM
cm storm trooper vs cm storm stryker owikhan2013 Case Mods, Worklog & Gallery 2 February 27, 2013 12:43 AM
GIGABYTE and Futuremark Host P55 OverclocKing Challenge and 10K Challenge Gav Press Releases & Tech News 1 November 13, 2009 03:31 PM
Challenge for you all-maybe get job out of it? magictorch Gaming 0 July 18, 2008 07:44 AM
