  #21 (permalink)
Old April 3, 2013, 06:32 PM
3.0charlie's Avatar
3.0charlie`s 3DMark - Ice Storm score: 150688 marks with a Radeon HD 7950
Hydro-Quebec is salivating...
  #22 (permalink)
Old April 3, 2013, 07:49 PM
ipaine's Avatar
So I have found something interesting. I think that the newest driver from Nvidia is reducing my performance on Ice Storm. The other day I ran it and got about 176000 and today with the newer drivers I just have barely cracked 171000 and that is with my card cranked way higher. I might just have to roll back a driver to test this.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
  #23 (permalink)
Old April 3, 2013, 07:59 PM
G777's Avatar
Interesting!
Another possibility to explore might be that your clocks are so high that the card is throttling during the test.
Whereas before you would simply see a driver crash, newer-gen cards can downclock to stay within the card's power/heat parameters.
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
  #24 (permalink)
Old April 3, 2013, 08:23 PM
ipaine's Avatar
Nope definitely the drivers.
So results with the exactly the same clocks 800 core 2048 mem 1600 shader
with 314.22 = 170670
with 314.07 = 176216
So there you go. I will do another run or two and get one of those submitted.
  #25 (permalink)
Old April 3, 2013, 08:37 PM
G777's Avatar
Great info, cheers!
Team Thread
  #26 (permalink)
Old April 3, 2013, 08:57 PM
Soullessone21's Avatar
running tests now oced my 660 only a little bit will clock it higher soon :)
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
  #27 (permalink)
Old April 3, 2013, 09:42 PM
ipaine's Avatar
So I finally cracked the 180k mark.
ipaine`s 3DMark - Ice Storm score: 180264 marks with a GeForce GTX 580
The thing is at least on the cloud gate and the fire strike benches my cards are only hitting about 50-60% usage. Very frustrating as I got a better score on fire strike with lower clocks by a long shot. Nothing sucks more than having temps in check and seeing only 11fps while the card is only running at 50-60%.
  #28 (permalink)
Old April 4, 2013, 08:46 AM
JayDeeHobbit's Avatar
There is something borked with my 3Dmark13 scores as well and is possibly driver related or ?...
I was getting very low scores on fire and after some searching I found there was a conflict with a MS update patch. I deleted the patch and now my fire score is over 10,000 where it should be.
But even on Ice there has to be a problem... If I disable SLI I get 165,000 on ice on a single GPU and with SLI enabled I get 180,000 so it's only a 10% bump from the second GPU = should be much more IMO.
I thought I had a eureka moment when I turned down my 120hz moinitor to 60hz but it didn't make any difference... Oh well I still have a few weeks to tweak some settings.
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
  #29 (permalink)
Old April 4, 2013, 08:56 PM
ipaine's Avatar
Ok so I got rid of that update mentioned by JayDeeHobbit and with that I noticed my fire strike and ice storm scores go up. So here is my newest and most likely best I'm going to get ice storm score.
ipaine`s 3DMark - Ice Storm score: 182205 marks with a GeForce GTX 580
  #30 (permalink)
Old April 5, 2013, 02:29 AM
Cool ipaine
But it seems you guys had better break out your multi-core multi-uber folding rigs for your Ice benchmaks.
I posted an Ice question on the Futuremark forums and my question/reply is here.
680 sli low score 3DMark - Page 3
HWC Overclocking Challenge #1: SuperPi 32M <4.0 Dead Things Overclocking, Tweaking and Benchmarking 79 March 31, 2013 09:43 PM
cm storm trooper vs cm storm stryker owikhan2013 Case Mods, Worklog & Gallery 2 February 27, 2013 12:43 AM
GIGABYTE and Futuremark Host P55 OverclocKing Challenge and 10K Challenge Gav Press Releases & Tech News 1 November 13, 2009 03:31 PM
Challenge for you all-maybe get job out of it? magictorch Gaming 0 July 18, 2008 07:44 AM
