Old March 25, 2013, 08:26 AM
Soullessone21's Avatar
Default Overclocking the A10-5800k to 5Ghz any one have luck with this?
So I want to hit the favored 5Ghz 24/7 heat is no issue got them up to 4.75ghz on 1.60Volts core but I wanna hit 5Ghz as this is replacing my 4.2Ghz 980X as our family computer.
Currently I have seen zero impact in games which amazes me. Even last night did a few tests with multiple games and no game play issues. I am using a 660 2gb OCed card and the onboard is shut off so that helps.
But anyone know the sweet spot settings for these APU's as they seem buggy to OC to say the least
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old March 25, 2013, 09:48 AM
G777's Avatar
I suspect you'll need a good amount of vcore to get to 5Ghz, and you'll be cooling limited before that.
Somewhere around 1.5-1.6v I'd guess
This is with Single Stage phase:
Edit: Should have read more carefully What are you using for cooling? 1.6v is probably pumping out a lot of heat I'd imagine...
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old March 25, 2013, 09:51 AM
hmm okay cooling is no issue it has not gone above 39c time to push the voltage more I need that 5ghz, 4k porn needs MHZ haha jk
Site and Forum:
Old March 25, 2013, 09:57 AM
G777's Avatar
In my limited experience with FM2 I can tell you that temp monitoring programs are rarely accurate.
Your porn is hotter than you think
Team Thread
Old March 25, 2013, 10:21 AM
BlueByte's Avatar
I was thinking about getting into some more exotic cooling and kind of dry running with FM2 boards since they are fairly inexpensive overall to setup. I would be interested in seeing what you get on your cooling setup, and what is your cooling setup.
Old March 25, 2013, 10:29 AM
Wow! 18 min for Super Pi 32M @5.2 GHz...that seems ssssllllllooooowwwww. Maybe my old Q6600 is not so bad.
Old March 25, 2013, 10:45 AM
I'm using an external heat monitoring source :) but the thing just hates running stable at high clocks.
Also got a 240 Seidon on it and it is cooling well :)
Valk he is running it as a dual core that could be why his scores bombed
Site and Forum:
Old March 25, 2013, 10:51 AM
G777's Avatar
That cooler is doing a heck of a job to hold <40 degrees loaded at that voltage.
Fyi: Super pi is not a multi-threaded bench... running it on less cores is faster
The quickest time on hwbot is still over 13 minutes
Team Thread
Old March 25, 2013, 10:53 AM
Hmmm.... I thought Super Pi was single threaded. ......
Looking fwd to the CC
edit: ninja'd by G777 of course
Old March 25, 2013, 06:35 PM
I keep my A10 at about 4.5 Ghz. I'm just using a Coolermaster 212+ with an extra fan. I find that when I push it to 4.6 or 4.7 in the multiplier it crashes on me. I have the CPU Voltage set to 1.475 Apart from bragging rights about the Ghz is there much of an advantage to 5 over 4.5? In theory everything should be 10% faster, but I have a feeling that is just a theory. I've spent too much time tweaking and trying to hit a "sweet spot" - right now I'm going for the sure and stable setting that I can rely on.
Be curious to see how this works out for you though?
FKD
Fort Kent, Alberta
2012 - A10 Rig
5800k, GA-F2A75M-D3H (FM2) supeg Price Check 1 March 13, 2013 12:28 AM
A10-5800K G777 Price Check 4 January 8, 2013 09:06 AM
AMD FM2 A10-5800K or A8-5600K? Soullessone21 CPU's and Motherboards 10 December 5, 2012 01:52 PM
a10-5800k build greenroost14 New Builds 4 October 10, 2012 09:28 PM
