Old March 22, 2013, 07:16 AM
Coach's Avatar
Default Owners of Cool labs liquid pro/ultra, I have questions for you
Is it worth it over decent TIM? I have a delidded 3770k and I am not sure if I should be pursuing this stuff. I was hoping those that have used it would chime in. Thank you
Phill
Old March 22, 2013, 07:40 AM
If you're happy with the temp drops you got after delidding with regular TIM, leave it at that.
What OC are you running at and what temps are you getting now?
Delidding didn't get me a better OC as my chip still requires a ton of voltage to go past 45x100. I wanted the extra couple of C drop Liquid Pro provides so I can run my fans as slow as possible for less noise. So to me it's worth $20 to run my fan at 400 rpm instead of 600 rpm.
heatware
Old March 22, 2013, 07:59 AM
Coach's Avatar
I am running 4.8 with 1.25v. Temps are ~70C. I used MX-2 originally and now I was thinking of rather using Liquid Ultra and then permanently gluing the IHS back the chip. From what I hear Cool Labs has a great product and it should improve my temps quite a bit... That is why I am trying to ask actually owners of the stuff to see if that is indeed the case.
Old March 22, 2013, 08:02 AM
I used Liquid Ultra on my 2500k... temps were down around 2-3 degrees from IC diamond. For the amount you get, id say its not worth it. 20$ for 3 applications... tops. I got 1, because half of mine leaked out the tip guard in shipping.
If you are never going to touch the heatsink, i guess its worth it. But if you remove the heatsink, to swap cases or w/e, dont bother using it.
Bought Items:
GTX 470 from ZeroFlux
Swiftech MCW60 from chubaka
Sold Items:
Steelseries Siberia V2 to MAK
Zalman Fan Controller, OCZ Mem Fan Funguseater
Lots of bad things happen in life all the time. You can't control them, so just be happy!
Old March 22, 2013, 09:02 AM
Coach's Avatar
I just want to use liquid ultra between the die and the bottom of the IHS. I should get many uses out of one syringe at that rate.
Old March 28, 2013, 07:15 PM
Coach's Avatar
Today my liquid Ultra arrived, Woot!! I will be using it on my delidded 3770k.
Q&A with Psyko Audio Labs @ HWC. Your Questions Answered SKYMTL Audio 57 October 14, 2009 10:12 PM
Q9550 to stock cool or custom cool? lKashl CPU's and Motherboards 11 June 11, 2009 04:33 AM
Cool Master Cosmos 1000 questions no_pulse Cases 6 March 24, 2008 11:45 AM
Q9300 review by X-bit labs yycraven Reviews & Articles from the Web 6 March 24, 2008 08:39 AM
HW Labs Radiators enaberif Water Cooling 9 February 8, 2008 06:19 PM
