Old March 18, 2013, 07:45 AM
Default which 3DMark do I buy
so just new to the whole benching scene. and I want to not waste any money so what futuremark products are a must to get into the benching scene?
Old March 18, 2013, 12:27 PM
All of the Futuremark products provide a free version. This free version allows you to run the benchmark at the default settings, which are the exact settings you have to run it at if you want to compare your scores with others running the benchmark. I would recommend you use the free versions until you find the one you are using the most. It is more convenient to have the paid version but its not essential and when your starting out its probably a good idea to get familiar with them first.
Old March 18, 2013, 03:29 PM
yycraven's Avatar
As Rasparthe said above, better to use the free ones first till you fine the one you like. 3Dmark vantage is the one I use the most.
Old March 18, 2013, 04:54 PM
Your_friendly_gamer's Avatar
i think I have an extra key for 3dmark vantage, you can have it for 1 coffee, tim hortons only! But I wont be able to get it for you until the we.ekend, probably Sunday
Trouble With 3DMark 11 noname2020x O/S's, Drivers & General Software 6 January 11, 2012 08:16 PM
3DMark + Win 7??? martin_metal_88 Troubleshooting 29 January 4, 2010 09:40 PM
PCMark and 3DMark kendallcschm Overclocking, Tweaking and Benchmarking 3 November 11, 2009 12:04 PM
DirectX and 3DMark.... keto Overclocking, Tweaking and Benchmarking 3 July 16, 2009 07:50 AM
Is this the highest 3dmark 06 on HWC? sheepdogexpress Overclocking, Tweaking and Benchmarking 8 May 14, 2009 12:48 AM
