Old March 16, 2013, 03:26 PM
JayDeeHobbit's Avatar
Default Overclocking from a NCIX built PC that they have OC'd
My new Vesta EVO i1 arrived yesterday so that means it's time for me to play with some overclocking.
Fail...
I'm actually trying to underclock from the NCIX shipped speed of 4.4ghz for the HWC SuperPi contest that requires a 4.0ghz speed for it's maximum.
So underclocking from the shipped speed = no problem... right? Nope.
I go into the BIOS and try to change the Multiplier from the 44 that NCIX shipped it and it will not let me. Oh I can change it but when I boot up it reverts to 44. Even loading the BIOS defaults will not change the multiplier.
I'm wondering if NCIX has the ability to go right into the chip itself to alter some settings. (in this case it's the ratio but perhaps other settings as well)
Does this sound reasonable. I can't imagine PEBKAC when I've selected "Load BIOS defaults" and even that won't override the ratio setting.
Edit: I should add I've tried many other settings as well without success... but surely restore defaults is the sledge hammer...
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
Old March 16, 2013, 03:45 PM
Xeven's Avatar
I've seen that happen from time to time on Asus flavors of the Z77 after using TurboV AutoTuning (P8Z77-V pro and sabertooth). However it is "fixed" after a few cycles of load-defaults, set-oc, save, reboot. It's weird but I never cared to investigate why or how exactly it happens.
PSXeven. Batards of the World Unite!
The gap between happiness and utter misery is only but a few inches
Old March 16, 2013, 03:57 PM
Thanks Xeven.
I've tried many different settings and I can alter things like the BCLK and have it stick but the ratio just will not budge.
Restore defaults, manual adjustment or using the ASUS OC utility... nothing can touch it that I've tried.
Using a sabertooth board BTW.
Old March 16, 2013, 05:14 PM
Dead Things helped me out over on NCIX.
A jumper reset cleared out the ratio.
Thanks DT
Chimp Challenge - NCIX and HWC to fold under team NCIX banner this year? JayDeeHobbit HardwareCanucks F@H Team 121 March 4, 2011 08:24 PM
OK I built it, now what? LaughingCrow Guides & How-to's 16 April 24, 2010 12:56 PM
AMD new built Chris New Builds 45 April 25, 2009 07:26 AM
Intel Core i7 Overclocking Guide on NCIX Tech Tips Linus CPU's and Motherboards 6 November 22, 2008 04:55 PM
