  #21 (permalink)
Old March 5, 2013, 08:39 PM
Perineum's Avatar
I'm hoping it works, cause that's a really weird problem....
  #22 (permalink)
Old March 6, 2013, 06:50 PM
looks like there is even a newer one.... maybe try this one?
EVGA Download Center
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
  #23 (permalink)
Old March 6, 2013, 06:56 PM
3.0charlie's Avatar
I searched for z68-sli. Is this the board you have on hand?
Weird, I do a search, and R16 is the latest. If R21 is indeed the latest, use that one.
Hydro-Quebec is salivating...
  #24 (permalink)
Old March 6, 2013, 06:59 PM
yes thats the board..went into fourms looked in motherboard section... there is a new one out... but it looks as though it has alot of bad reviews... no memory overclocking... some even reverted back....
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
  #25 (permalink)
Old March 6, 2013, 07:01 PM
3.0charlie's Avatar
I'd stick to R16 then. And eventually upgrade if needed.
  #26 (permalink)
Old March 6, 2013, 09:59 PM
Your_friendly_gamer's Avatar
What is that dummy oc thing on your bios settings? Have you tried enabling it?
  #27 (permalink)
Old March 7, 2013, 10:26 PM
Just a quick reply before it's bedtime. I am struggling with something very similar. I am running a 2600K in a P8Z68-v Pro/Gen3 mobo that I have oc'd in the past but due to ignorance it was unstable so I ran it stock for a while. Now after educating myself (i think) and successfully oc'ing a 2nd 2600K in a P67 Sabertooth, I thought I'd take another crack at my first machine. So I've update to the latest bios and I've pretty much copied my settings from my P67 oc but this time my settings are just simply ignored. I double checked my bios settings from in Windows with AI Suite and it confirms the settings but cpu-z and AI Suite both show the cpu is only clocking at 3.4 ghz under load. If I change the oc settings with AI Suite, it just keeps ignoring them. It seems as though the mobo detects a "K" cpu and allows access to the settings to change them, but then it ignores them as if it's a non-K cpu. I'll get into more details tomorrow.
  #28 (permalink)
Old March 7, 2013, 11:43 PM
ZZLEE's Avatar
My i7 3770K on my Asus P8Z77-I deluxe has a locked multi of 47. I cant seem to rase it or lower it.
I have been playing a bit in Bios some of its locked but not all.
I think its Microsoft but Im not sure how to prove it.
WIN 7 64 bit Ultimate SP1
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #29 (permalink)
Old March 8, 2013, 09:35 PM
So I have discovered that enabling hyperthreading in my bios prevents it from oc'ing my cpu. Also, when HT is enabled, win7 does not actually detect it anyways. So now I'm running 4.7GHZ at about 1.368 volts.
  #30 (permalink)
Old March 9, 2013, 04:20 PM
does cpuz or any program show the overclock?
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Sign the Poutition Killswitch Off Topic 0 April 27, 2012 06:28 PM
[WTB] BQ campaign sign FlyingFish Buy/Sell & Trade 61 April 13, 2011 09:47 PM
Sign... 486 Off Topic 17 October 14, 2009 12:34 PM
who can sign a passport photo? xghostz Off Topic 17 October 15, 2008 10:28 AM
Guests, You Should Sign Up!! arekieh Suggestions & Feedback 13 October 8, 2008 03:14 PM
