  #61 (permalink)
Old July 18, 2013, 01:44 PM
Hm with free version i have to run all the benchmarks,but my card is whining horribly on the first one,because i have an insane amount of FPS,is that ok?
  #62 (permalink)
Old July 18, 2013, 07:41 PM
great_big_abyss's Avatar
Hmmm, almost identical to yours. Will try with an OC next. GPU was running at 1215 on that last one.
  #63 (permalink)
Old July 18, 2013, 08:58 PM
Here is one with a 100Mhz OC on it. GPU was running at 1318Mhz. Tried it at +155Mhz, but it crashed half way through.
  #64 (permalink)
Old July 19, 2013, 05:36 AM
Strange,no difference whatsoever! Probably because this benchmark does not use a lot of CPU power...i even got a better score on the first run...lol
Would not be the same for planetside 2
  #65 (permalink)
Old July 19, 2013, 06:00 AM
I think my MSI may be slightly downclocked compared to your ASUS, which would explain the slightly higher scores that you have when my card is stock clocked.
I'm certain that if we both had SLI 770's, then we'd see more of a difference as I think your CPU would then start to bottleneck you a little.
  #66 (permalink)
Old July 19, 2013, 10:04 PM
Minor increases. Increased OC to 135 Mhz, for a total of 1350Mhz Boost. Not sure she has any more left in her. The last run I tried at +150 Mhz crashed and burned during valley. This is with the voltage adj turned up to +12mV.
  #67 (permalink)
Old July 20, 2013, 03:41 AM
Well i tried to overclock memory after all, and it didn't work great with mine,core is fine though,but i tried at 7300mhz memory and no artifacts but the card slowed down at the middle of the benchmark,slowed down by 80-100% the card was still indicating the right clocks though
I had to restart computer to clear memory. I will stay with 7100 memory because anyway i didn't notice huge improvements.
i got a score of 2002 with 1220 mhz on the core.
  #68 (permalink)
Old July 20, 2013, 07:00 AM
Ya, I've never had great luck overclocking VRAM. So I never bother anymore. My justification is it's fast enough these days anyways. Memory bandwidth isn't really a problem.
  #69 (permalink)
Old July 30, 2013, 05:34 AM
A friend just sent that to me -_________-
Unigine benchmark results
  #70 (permalink)
Old November 23, 2013, 05:28 PM
rjbarker's Avatar
Havent posted up on here in awhile....this Thread really should be a "sticky" with the other Benches..MK11, MK13, Vantage etc....
Anyhow...obviously everything OC'd pretty high:
3930K @ 5.1 Ghz
SLi 780Ti +75mv / +161 Mhz Core / +301 Mhz Memory
Firestrike Extreme: 21.452
MARK 11: 32.530
Unigine Heaven 2.0 Benches rjbarker Overclocking, Tweaking and Benchmarking 8 April 13, 2010 08:33 AM
Unigine Heaven 2, Tesselation, and directx 11 MarkOne Gaming 17 March 24, 2010 04:23 PM
were can i find 80/20 aluminum extrusion tubing in Fraser Valley kyle_L Off Topic 7 August 18, 2009 07:51 AM
Big Valley Jamboree tzetsin Off Topic 0 July 25, 2009 12:11 PM
Flooding in the Fraser Valley? sswilson Off Topic 7 June 2, 2007 08:54 PM
