  #51 (permalink)
Old June 28, 2013, 11:59 PM
rjbarker's Avatar
^^^ No, when running SLi the clocks are not "locked". You can still OC both the Core and the Memory ;)....you can do this one of 2 ways, within Precision X you can either OC both the Memory and Core indidually or in "synch" mode, the latter being OC'ing all 3 Cards to the same settings.
In my case, having one Card clocked 40 Mhz higher means if I OC my Cores in "synch mode", I'll push al 3 Cards up in a value by whatever I choose. The one Card will always be 40 Mhz faster than the other 2, a work around would be to OC each Card individually, bringing 2 Cards up to the same Core speed as the one that is clocked 40 Mhz higher.....but OC'ing individually is a pita and not the worth the effort.
To be perfectly honest, having 3 Cards already pushing 1200 Mhz with factory OC, there treally is no need to OC higher, other than for Bench runs.
From what I have seen so far, the Cards are still being held back slightly by the CPU, yes even at 4.7 Ghz....when I tried some runs at 4.9 Ghz, Graphic scores jumped by a good margin ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
  #52 (permalink)
Old June 29, 2013, 12:01 AM
rjbarker's Avatar
Here's a run at 4.9 Ghz....same GPU OC's as previous...
MARK 11: 32.530
  #53 (permalink)
Old June 29, 2013, 01:56 AM
Dzzope's Avatar
Just depends on the application / game / bench really.. seen before that CPU is used quite heavily in this bench.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #54 (permalink)
Old June 29, 2013, 03:48 PM
rjbarker's Avatar
^^^^^ Bottomline...I believe we have finally hit the point in GPU technology, that in most cases (particularly running SLI), the faster you can get your CPU running, the happier your GPU's will be ;)
Honestly....we need CPU's running at 5.5 Ghz to 6 Ghz ;)
MARK 11: 32.530
  #55 (permalink)
Old June 29, 2013, 04:13 PM
Dzzope's Avatar
Depends how optimized for multi threaded cpu usage they need and at that how much they use.. all about the coding and hence the application.
Random quotes:
  #56 (permalink)
Old July 18, 2013, 07:16 AM
  #57 (permalink)
Old July 18, 2013, 08:05 AM
Dzzope's Avatar
Do a run of 3dmark too . :)
nice score.
Random quotes:
  #58 (permalink)
Old July 18, 2013, 08:09 AM
great_big_abyss's Avatar
So, I'm looking forward to comparing my score this evenining with Bliz's. I have a single 770 running at similar clocks to Bliz's, the difference is I have a 3770K OC'd to 4.5 vs a 2500 @ 3.3. I'm looking forward to see exactly what difference CPU makes in this particular benchmark.
  #59 (permalink)
Old July 18, 2013, 09:20 AM
nice score.
3d mark is not free,only the 720p benchmark is free i think,you want me to do it?
Yeah abyss i can't wait to see your scores!
  #60 (permalink)
Old July 18, 2013, 12:31 PM
Dzzope's Avatar
Yea.. go for it.. Fire-strike is pretty intensive even in the free version.
Not sure a single 770 will be CPU bound enough to show huge difference.. But hey still interesting to see the numbers...
I can't wait to get my new rig and see what it brings my 780 up to... and then what SLI brings. :D
Random quotes:
Unigine Heaven 2.0 Benches rjbarker Overclocking, Tweaking and Benchmarking 8 April 13, 2010 08:33 AM
Unigine Heaven 2, Tesselation, and directx 11 MarkOne Gaming 17 March 24, 2010 04:23 PM
were can i find 80/20 aluminum extrusion tubing in Fraser Valley kyle_L Off Topic 7 August 18, 2009 07:51 AM
Big Valley Jamboree tzetsin Off Topic 0 July 25, 2009 12:11 PM
Flooding in the Fraser Valley? sswilson Off Topic 7 June 2, 2007 08:54 PM
