  #31 (permalink)
Old June 13, 2013, 07:44 PM
great_big_abyss's Avatar
Here is the main rig. 1920x1200, Extreme HD preset, so Ultra & 8x AA
And, here is the HTPC: 720P, Ultra setting, 8x AA
  #32 (permalink)
Old June 13, 2013, 08:19 PM
rjbarker's Avatar
Firestrike Extreme: 21.452
MARK 11: 32.530
  #33 (permalink)
Old June 13, 2013, 09:12 PM
lowfat's Avatar
CPU bottleneck in almost all tests. But that is what I get for using stock clocks.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #34 (permalink)
Old June 13, 2013, 10:39 PM
rjbarker's Avatar
Unigine shows 1 GPU (x1)....funny eh...look at the min max compared to a couple of 680's....
MARK 11: 32.530
  #35 (permalink)
Old June 13, 2013, 11:08 PM
lowfat's Avatar
Because I am assuing you have your CPU @ 4.7GHz. Valley is very CPU dependent.
Here is a quick run w/ the CPU now @ 4.6GHz instead of stock. Same GPU clocks as I ran above.
Queen of Dreams WIP
Big Lian Li
Complete
  #36 (permalink)
Old June 17, 2013, 10:00 AM
hero1's Avatar
This is weird. My card won't clock past +90 I do get max boosts pf 1202 but memory clocks won't go past 3139 MHz.. any suggestion.. and this is regardless of voltage..agh and it looks like my CPU is indeed bottlenecking my GPU..
  #37 (permalink)
Old June 18, 2013, 01:14 AM
hero1's Avatar
This is done with the Extreme Settings. I need a better CPU, I might as well just grab a 3930K and RIVE and go from there!
  #38 (permalink)
Old June 18, 2013, 10:29 AM
Kindred1's Avatar
whats wrong with a 3570k ?
my Scores are my res is windowed cause my monitor is a 1680
System : Cosmos 1000 Maximus IV Gene-Z i7 2600k 4.8 Ghz Gskill 16GB 1866 2x EVGA GTX 980 SC HX 750i Bootdrive: Samsung 840 Pro 256,128 Storage :Seagate 1TB
Watercooling Setup : Thermochill Pa120.3 Swiftech MCR120-QP EK Supremacy 2x Swiftech MCW6000 Phobya Balancer 250 Reservoir Swiftech MCP350 Modded with 18W DYINHK PCB Swiftech MCP655
  #39 (permalink)
Old June 18, 2013, 11:22 AM
hero1's Avatar
I just see it bottleneck my GPU and it would be so when I get the second one in there.
  #40 (permalink)
Old June 19, 2013, 10:23 PM
hero1's Avatar
Do you have the cards that have the stock cooler? My hydro copper with +78 which translates to 1110 can only boost to 1202 Max. What can yours do?
Unigine Heaven 2.0 Benches rjbarker Overclocking, Tweaking and Benchmarking 8 April 13, 2010 08:33 AM
Unigine Heaven 2, Tesselation, and directx 11 MarkOne Gaming 17 March 24, 2010 04:23 PM
were can i find 80/20 aluminum extrusion tubing in Fraser Valley kyle_L Off Topic 7 August 18, 2009 07:51 AM
Big Valley Jamboree tzetsin Off Topic 0 July 25, 2009 12:11 PM
Flooding in the Fraser Valley? sswilson Off Topic 7 June 2, 2007 08:54 PM
