Old February 26, 2013, 07:27 AM
Dzzope's Avatar
Nope he has a 920@3.8 but I just noticed he has sli 680's.. might be down to the processor between mine and Phills though(for such a large gap).
Old February 26, 2013, 12:32 PM
lowfat's Avatar
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old February 26, 2013, 01:13 PM
IRQ Conflict's Avatar
As with the Heaven bench, Valley does not seem to benefit much from a (CPU) clock boost. The higher score is from an extra 1000Mhz to the core.
Old February 26, 2013, 05:01 PM
Zer0's Avatar
2500K @ 4.5Ghz
EVGA GTX 680 SC Signature (stock clocks)
Old February 26, 2013, 11:49 PM
Rollergold's Avatar
Re ran with +50 Mhz on the GPU clock on GPU 1, +25 MHz GPU clock for GPU 2 and +400 MHz on the memory clock for both
It's achually @ 4.0GHz, Valley is reading the clock speed wrong.
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
Old February 28, 2013, 07:57 AM
JayDeeHobbit's Avatar
My new rig next week should do better.
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
Old March 15, 2013, 11:32 PM
I ran 3Dmark and found my new SLI 670's scored worse on fire than my single 570 on my old rig.
Made me think there were problems.
Unigine seems to be behaving though...
Old March 16, 2013, 01:40 AM
Yeah, Multi GPU setups don't always work. You might need a different driver?
  #19 (permalink)
Old March 16, 2013, 11:24 AM
yycraven's Avatar
Tried it out with my new mobo and cpu as well ram.
Cards still GTX 470's SLi
  #20 (permalink)
Old March 16, 2013, 11:48 AM
Perhaps a new driver will do the trick in 3Dmark IRQ.
I am not worried about it at this point though. I just got the rig yesterday and was just running the benchies to make sure it was working. When I got crud results on the Fire area I was hoping I hadn't stumbled on a problem.
Unigine Heaven 2.0 Benches rjbarker Overclocking, Tweaking and Benchmarking 8 April 13, 2010 08:33 AM
Unigine Heaven 2, Tesselation, and directx 11 MarkOne Gaming 17 March 24, 2010 04:23 PM
were can i find 80/20 aluminum extrusion tubing in Fraser Valley kyle_L Off Topic 7 August 18, 2009 07:51 AM
Big Valley Jamboree tzetsin Off Topic 0 July 25, 2009 12:11 PM
Flooding in the Fraser Valley? sswilson Off Topic 7 June 2, 2007 08:54 PM
