-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   How high can I overclock my Sapphire HD7950 Vapor-X (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/59787-how-high-can-i-overclock-my-sapphire-hd7950-vapor-x.html)
ern88 February 20, 2013 03:48 PM
I am wondering about optimal o/c my HD 7950 vapor-X. I have it set at core is 1025 and memory 1325. Can I safely go higher than that?
Masteroderus February 21, 2013 10:23 AM
It can handle a higher overclock, but you're entering the danger zone! Use sapphire trixx or msi afterburner. Try and keep temps under 80.
Adzsask February 21, 2013 10:29 AM
my non vapor X sapphire does 1200 core on stock max voltage and 1300 at least with a little extra juice. Only tried as high as 1375 on my memory.
ern88 February 22, 2013 11:59 AM
What would be optimal o/c settings to use?
Adzsask February 28, 2013 08:59 AM
Plenty of guides out there, I personally max stock voltage limits and see how high it goes by upping one thing at a time in 20MHz increments.
sf101 March 1, 2013 07:06 PM
been running my 7970 @ 1285 - 1850 (core / mem) for over a year.
if you have decent cooling and decent mem on the card. its possible to go further
sourthings March 1, 2013 07:20 PM
You can push it more I would think. I have a MSI 7950 TF3 in a system here running at 1.2ghz with 1.25V.
Go for it.
x2ezx March 6, 2013 01:58 AM
It all about cooling!
