Old March 17, 2007, 03:26 PM
r0k0's Avatar
i dont have problems....yet
Old March 17, 2007, 04:03 PM
Babrbarossa's Avatar
I wish I could help- I've never overclocked an AMD before- I'm sure you've seen this link, and it certainly doesn't answer all the questions, but it gives an idea of what they're capable of:
http://www.pcstats.com/articleview.cfm?articleID=1815
Old March 17, 2007, 06:02 PM
sswilson's Avatar
I'm wondering what you're asking then?
In order to OC an AMD you need to raise the HTT(fsb) while keeping your HT below 1000, and watching your mem (it's better to find the max of cpu & mem on their own first by keeping the other low, and then find the best mix based on those individual limits).
You're probably safe going right up to 230, but after that try increments of 5 and test.
Keep an eye on your temps using something like speedfan (60c is the absolute max under load, and I usually get a bit squeemish when it starts going over 50c).
3DMark `03 & superpi are pretty good short time benchmarks (`03 will usually gack on either the first or second tests if you've pushed either the cpu or the mem too far) & prime95 for longterm stability tests. (Usually if you get an error after more than 5 minutes you can try a small bump in vcore).
Highest "safe" vcore for that chip is widely accepted as being around 1.55 (I'm running 1.65) but with stock air, you probably won't be able to get that high while still keeping acceptable temps.
Old March 17, 2007, 09:40 PM
r0k0's Avatar
how do i keep my HTT low and humm all...
if i hot 230FSB i'll have my cpu clocked a 2.3Ghz
Old March 17, 2007, 09:58 PM
sswilson's Avatar
Try dropping your "northbridge fsb" setting in bios and see if that drops your HT in cpu-z.
Your chip normally runs @ 200X11=2200 so 230X11=2530. Your mem @ 230 1-1 will be running @ DDR460 well below the DDR500 it's rated for.
Ideally if you can get your chip to run @ 250 within safe temps you'll get full benefit of your stock mem settings (DDR500) as well as a fairly decent cpu OC (2750) but that would probably take 1.6 vcore and your temps will probably be pretty high.
Old March 17, 2007, 11:05 PM
r0k0's Avatar
i know that 230x11 its 2530mhz but like i said putting my fsb to 221 and higher my multiplier goes automaticly to 221x10
Old March 17, 2007, 11:12 PM
r0k0's Avatar
Found it
the FID/VID Change lets me put the multiplier and vcore
im at 225FSB and 2475mhz right now.. i'll test it higher tomorow
if i can get 2.6, 2.7Ghz i'll be the happiest of all :P
sswilson's Avatar
Ummmmmmm that's pretty damn wierd............. This isn't an "AMD overclocking" thing it's a board thing......
Is there a setting somewhere for manual OC? Sounds like there's some wierd board auto OC thingy going on........
  #19 (permalink)
Old March 17, 2007, 11:13 PM
sswilson's Avatar
Originally Posted by r0k0 View Post
Found it
Heh... ok that's better.... :)
  #20 (permalink)
Old March 18, 2007, 01:04 PM
r0k0's Avatar
do you think my cpu will hit the same has you...?305x10 :P or 277x11 would be better for 3ghz haha
Quaddro FX 3700 = 8800GT? Babrbarossa Video Cards 2 January 27, 2008 07:51 AM
