<~----> 1.65v ram on sandy bridge - Hardware Canucks
Old February 7, 2013, 04:23 PM
Default 1.65v ram on sandy bridge
Hi,I was wondering if ruining my Kingston 8 gb ram kit (1.65v cl9) Will cause any issues with my pentium g870.I have heard that ram kits over 1.5v are bad for sandy bridge,and I was wondering if I will void my warranty by using the ram at 1.65 volts,or if it is in my best interest to run them at 1.5v?
Thanks,
Old February 7, 2013, 04:24 PM
supaflyx3's Avatar
It should be fine to run it at 1.65, you can always try running it at 1.5 and running memtest to see if its stable.
Old February 7, 2013, 04:29 PM
I am trying it at 1.5v right now (testing with memtest.)But If I do run them at 1.65v,will my warranty be void?
Old February 7, 2013, 05:28 PM
IRQ Conflict's Avatar
As far as I know exceeding the spec (speed/voltage) the manufacturer set will void the warranty unless specified by the manufacturer that it's OK to do so.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
Old February 7, 2013, 08:06 PM
Well I tested thwm at 1333 cl9@ 1.5v,and they were fine.I'm going to keep them this way as to not void my warranty.Also,I was only runing them at 1.65 volts for 3 weeks or so,and they were hardly being used during that time.But I cant imagine I have done any damage to the cpu during such a short period of time.
Old February 7, 2013, 08:10 PM
Over volting your ram shouldn't effect the CPU at all. Probably shorten the life of the ram though.
Old February 8, 2013, 01:16 AM
Silvgearx's Avatar
I run 1.65v ram with Sandy, no problem.
Old February 8, 2013, 05:12 AM
botat29's Avatar
wrong, over volting the ram can damage the CPU ; with SB the memory controller is build in the CPU. Anyway the OP want to under volts not over.
Old February 8, 2013, 06:27 AM
I contacted Intel support and they said it was fine that the ram was over volted , because it has an XMP profile.Provided I continue to run the kit a 1.5v I will get my full Processor warranty.
[WTB] Sandy Bridge i5 CPU nakano2k1 Buy/Sell & Trade 0 January 2, 2013 07:05 AM
Sandy bridge and Z77 BrutalGreen Overclocking, Tweaking and Benchmarking 0 June 3, 2012 09:48 AM
Wait or Ivy Bridge? Or Bite the Sandy Bridge? geokilla CPU's and Motherboards 14 April 11, 2012 10:37 AM
sandy bridge E or wait for ivy bridge for 1155 gingerbee Off Topic 4 February 1, 2012 08:07 PM
[WTB] WTB: sandy bridge cpu and SSD dpk33 Buy/Sell & Trade 7 January 15, 2012 08:15 PM
